Community
cancel
Showing results for
Search instead for
Did you mean:
Enable GPIO Interrupt on two GPIO_SS pins at same time
Hi All,
I have to Configure two GPIO_SS Pins for detecting interrupt simultaneously.
Actually I Connected two GPIO interrupt based sensors on GPIO_SS PIN 2 and 6. I already wrote, run and tested the separate code for these sensors having GPIO Interrupt enabled and it is working fine.
But Now when I merged these two code in one code, I am unable to get the expected result. There is no compilation or run time error but this code not detecting the sensor data.
Anemometer is connected to GPIO_SS [2].
Rain Gauge is connected to GPIO_SS [6].
Both are working fine with separate codes anemometer_main.c and rain_gauge_main.c respectively.
After merging these two codes and writing anemometer_and_rainguage_merged_main.c I am unable to get the data from any of sensors.
I am attaching the separate codes and the merged code.
Please have a look and suggest my what i did wrong.
Thanks & Regards
Rohit
