I want to be able to do an OTA update from the SD card. To do this I need to make the SD card accessible from u-boot. I've done basically the same thing as this guy: https://gist.github.com/plusk01/ad5324aa36191693c07c Researching how to do U-Boot OTA using the external SD card on the Intel Edison · GitHub . My changes weren't correct and now u-boot hangs and resets after a few seconds (relevant error: "sdhci_reset: Reset 0x1 never completed").
Has anyone gotten the SD card working in u-boot?
How does one recover from a bad u-boot image? I have a known good u-boot in mmcblk0p3.
Hi jpkotta,
It would be necessary to check the startup log of your Edison to see where the error is occurring exactly. Could you please provide a screenshot(s) of this? Please share your log from "PSH KERNEL VERSION: xxxxxxxx" to the point it gets stuck. Depending on where the software is hanging it should be possible to recover it.
Also, what did you do wrong about the tutorial that you shared? You mentioned that your changes weren't correct, we would like to know what the error was.
-Pablo
PSH KERNEL VERSION: b0182b2b
WR: 20104000
SCU IPC: 0x800000d0 0xfffce92c
PSH miaHOB version: TNG.B0.VVBD.0000000c
microkernel built 11:24:08 Feb 5 2015
******* PSH loader *******
PCM page cache size = 192 KB
Cache Constraint = 0 Pages
Arming IPC driver ..
Adding page store pool ..
PagestoreAddr(IMR Start Address) = 0x04899000
pageStoreSize(IMR Size) = 0x00080000
*** Ready to receive application ***
U-Boot 2014.04 (Jun 22 2016 - 16:39:32)
Watchdog enabled
DRAM: 980.6 MiB
MMC: sdhci_reset: Reset 0x1 never completed.
tangier_sdhci: 0, tangier_sdhci: 1
In: serial
Out: serial
Err: serial
I found https://github.com/01org/edison-u-boot/tree/edison-v2015.10 https://github.com/01org/edison-u-boot/tree/edison-v2015.10, which has code to enable the SD card, which I'm trying to backport to my version (2014.04). That code has the correct invocation of tangier_sdhci_init(), but I was missing power_init_board(); I'm pretty sure that's why it's not working. Here's a diff of the code:
int board_mmc_init(bd_t * bis)
- int index = 0;
- unsigned int base = CONFIG_SYS_EMMC_PORT_BASE + (0x40000 * index);
- return tangier_sdhci_init(base, index, 4);
+ int err;
+ err = tangier_sdhci_init(CONFIG_SYS_EMMC_PORT_BASE, 0, 4);
+ if (err) {
+ goto exit;
+ err = tangier_sdhci_init(0xff3fa000, 0, 4);
+ if (err) {
+ printf("sdcard init failed: %d\n", err);
+ err = 0;
+exit:
+ return err;
Anyway, before I hose any more Edisons, I'm trying to figure out how to test code without overwriting u-boot. I'm pretty close to getting that working with http://www.denx.de/wiki/view/DULG/UBootStandalone http://www.denx.de/wiki/view/DULG/UBootStandalone.
Hi jpkotta,
From your log, it should be possible to flash the Edison image to recover it. If you're unsure on how to proceed with this check this guide: /docs/DOC-98643 https://communities.intel.com/docs/DOC-98643. I noticed that you already know what caused the issue, so after recovering your Edison you can continue with your testing (even if you're already close to test without overwriting u-boot). This seems like a nice project, it would be nice to see your final results once you're done with it.
-Pablo
Hi jpkotta,
Do you have updates on this case? Were you able to test with the AlexT repository?
-Pablo
I can flash over bad u-boot images with the FlashToolLite. I was also able to get standalone programs working, but I was still missing something to enable the SD card controller. So then I tried to just use the 2015.10 branch from the 01org github, and it works so far.
Here's my recipe, which may still need modifications:
# u-boot_2015.10.bb
require recipes-bsp/u-boot/u-boot.inc
PV = "2015.10-1"
S = "${WORKDIR}/git"
PACKAGE_ARCH = "${MACHINE_ARCH}"
SRC_URI = "git://github.com/01org/edison-u-boot.git;branch=edison-v2015.10"
# SRC_URI += "file://upstream_to_edison.patch"
SRC_URI += "file://${MACHINE}.env"
SRC_URI += "file://target_env/*.env"
SRCREV = "2e2b030bc6ed039b3b27225ee3486bd5b5d9f5a4"
require recipes-bsp/u-boot/u-boot-target-env.inc
require recipes-bsp/u-boot/u-boot-osip.inc
LICENSE = "GPLv2+"
LIC_FILES_CHKSUM = "file://Licenses/README;md5=0507cd7da8e7ad6d6701926ec9b84c95"
