Community
cancel
Showing results for
Search instead for
Did you mean:
Highlighted
New Contributor III
Enabling USB HID Gadget Support
https://www.kernel.org/doc/Documentation/usb/gadget_hid.txt https://www.kernel.org/doc/Documentation/usb/gadget_hid.txt has some info on enabling g_hid / config fs.
https://wiki.tizen.org/wiki/USB/Linux_USB_Layers/Configfs_Composite_Gadget/Usage_eq._to_g_hid.ko https://wiki.tizen.org/wiki/USB/Linux_USB_Layers/Configfs_Composite_Gadget/Usage_eq._to_g_hid.ko also has some great stuff
I rebuilt the kernel with usb gadget+hid support, but there must be more to it.
root@edison:/# ls /lib/modules/3.10.17-poky-edison\+/kernel/drivers/usb/gadget/
g_hid.ko gadgetfs.ko u_serial.ko
g_multi.ko libcomposite.ko usb_f_acm.ko
root@edison:/# modprobe g_hid
modprobe: ERROR: could not insert 'g_hid': No such device
Here is something similar for the beagleboard, and they talk about adding stuff to hid.c from the gadget_hid.txt above, but I'm not sure which hid.c they are referring too.
http://www.linuxquestions.org/questions/linux-newbie-8/linux-usb-gadget-hid-driver-problem-840733/ http://www.linuxquestions.org/questions/linux-newbie-8/linux-usb-gadget-hid-driver-problem-840733/
Thanks in advance,
@hippiehacker
Highlighted
Hi @hippiehacker
The hid.c that they are talking about is the code that appear in the that link. Let's try with that first. Also, are you connecting the device to the USB port and putting the switch (SW1) closer to that port?
Regards;
CMata
Highlighted
New Contributor III
I'm using the edison breakout board and power is supplied over the OTG, (I connect both ports).
Highlighted
New Contributor III
I'm still not sure I understand which hid.c file within the edison-src directory it's referring too.
edison-src/build/tmp/work/x86_64-linux/qemu-native/1.7.0-r0/qemu-1.7.0/hw/bt/hid.c
edison-src/build/tmp/work/x86_64-linux/qemu-native/1.7.0-r0/qemu-1.7.0/hw/input/hid.c
edison-src/build/tmp/work/core2-32-poky-linux/linux-libc-headers/3.14-r0/linux-3.14/drivers/usb/gadget/hid.c
edison-src/build/tmp/work/edison-poky-linux/linux-yocto/3.10.17+gitAUTOINC+6ad20f049a_c03195ed6e-r0/linux/drivers/usb/gadget/hid.c
step1: go to the link below.
http://www.mjmwired.net/kernel/Documentation/usb/gadget_hid.txt http://www.mjmwired.net/kernel/Docum...gadget_hid.txt
step2: copy the following two structures from the above link and paste into hid.c
hidg_func_descriptor
platform_device
step3: compile the hid module
step4: load the module
Hi
In your hidg_init function in the module, call the following
Code:
int status; status = platform_device_register(&my_hid); if (status < 0) { platform_driver_unregister(&my_hid); return status; }
where my_hid is a pointer to platform_device struct.
Also call the following function in your hidg_cleanup function
platform_device_unregister(&my_hid);
Hope this will help.
Highlighted
New Contributor III
I'm thinking it's probably something that needs to be in the upstream_to_edison.patch
# grep \| edison-src/device-software/meta-edison/recipes-kernel/linux/files/upstream_to_edison.patch | grep usb/
drivers/usb/core/hcd.c | 23 +-
drivers/usb/dwc3/Kconfig | 66 +
drivers/usb/dwc3/Makefile | 10 +-
drivers/usb/dwc3/core.c | 21 +-
drivers/usb/dwc3/core.h | 71 +
drivers/usb/dwc3/debugfs.c | 49 +
drivers/usb/dwc3/dwc3-device-intel.c | 648 +++
drivers/usb/dwc3/dwc3-host-intel.c | 724 +++
drivers/usb/dwc3/dwc3-intel-byt.c | 970 ++++
drivers/usb/dwc3/dwc3-intel-mrfl.c | 992 ++++
drivers/usb/dwc3/dwc3-pci.c | 4 +
drivers/usb/dwc3/ep0.c | 37 +-
drivers/usb/dwc3/gadget.c | 1085 +++-
drivers/usb/dwc3/gadget.h | 7 +
drivers/usb/dwc3/otg.c | 1509 +++++
drivers/usb/dwc3/otg.h | 432 ++
drivers/usb/gadget/epautoconf.c | 42 +
drivers/usb/gadget/f_dvc_dfx.c | 922 ++++
drivers/usb/gadget/f_dvc_trace.c | 887 +++
drivers/usb/gadget/f_mass_storage.c | 2 +-
drivers/usb/gadget/gadget_chips.h | 5 +-
drivers/usb/gadget/multi.c | 37 +-
drivers/usb/gadget/u_ether.c | 2 -
drivers/usb/gadget/u_serial.c | 2 +-
drivers/usb/gadget/udc-core.c | 12 +-
drivers/usb/host/ehci-pci.c | 2 +-
drivers/usb/host/xhci-plat.c | 11 +
drivers/usb/phy/penwell_otg.c | 5780 ++++++++++++++++++++
include/linux/usb/debug.h | 253 +
include/linux/usb/dwc3-intel-mid.h | 190 +
include/linux/usb/dwc3-intel-mrfl.h | 168 +
include/linux/usb/gadget.h | 4 +
include/linux/usb/hcd.h | 3 +
include/linux/usb/penwell_otg.h | 515 ++
include/linux/usb/phy.h | 14 +
include/uapi/linux/usb/ch9.h | 1 +
Highlighted
New Contributor III
Another approach that adds platform_device_register(&my_hid) to KERNEL/arch/arm/mach-omap2/board-am335xevm.c.
Looks like we need to find the right c files for the edison.
http://stackoverflow.com/questions/9847391/omap-udc-c-g-hid-c-hid-gadget-on-beagleboard-with-angstro... embedded - omap_udc.c g_hid.c hid gadget on beagleboard with angstrom linux - Stack Overflowhttp://www.linuxquestions.org/questions/linux-newbie-8/linux-gadget-hid-driver-insert-error-944553/ /
Highlighted
New Contributor III
I tried just compiling intel's patch(1) to 3.10.17 with CONFIG_USB_GADGETFS=m CONFIG_USB_G_HID=m but I get an error trying to load the module:
According to https://www.kernel.org/doc/Documentation/usb/gadget_hid.txt https://www.kernel.org/doc/Documentation/usb/gadget_hid.txt:
g_hid is a platform driver, so to use it you need to add struct platform_device(s) to your platform code defining the HID function descriptors you want to use
It's not clear to me what part of the platform code I should be adding, but I assume it's something under:
https://github.com/instantinfrastructure/linux-yocto-3.10/tree/edison/arch/x86/platform/intel-mid https://github.com/instantinfrastructure/linux-yocto-3.10/tree/edison/arch/x86/platform/intel-mid
Highlighted
New Contributor III
I did find a demo for the beagleboard black:
https://github.com/csimmonds/g_hid-demo csimmonds/g_hid-demo · GitHub
This is a quick and dirty hack to demonstrate the gadget hid driver. Normally the platform_device descriptor would be part of the board support for the device, e.g. in arch/arm/mach-omap2/devices.c, but for convenience I am putting it in to the g_hid module to make easier for testing.
Copy this file over the one in drivers/usb/gadget, build the g_hid module and copy to the device.
Highlighted
Hi @hippiehacker
Let me know about your last test, also, have you tried with another method I think that http://www.linuxfromscratch.org/blfs/view/svn/general/usbutils.html usbutils could work and what kind of device do you want to connect? A mouse, keyboard, joystick?
Regards;
CMata
Highlighted
New Contributor III
I've reached out to the linux-usb mailing list and got a response: http://article.gmane.org/gmane.linux.usb.general/120297 http://article.gmane.org/gmane.linux.usb.general/120297
I'm not sure where to add this stuff to the platform. It was suggested ask on an intel-mid platform specific mailing list.
We have the patches supplied by intel
https://github.com/instantinfrastructure/edison-src/blob/master/device-software/meta-edison/recipes-... edison-src/upstream_to_edison.patch
Which completely provides the platform/intel-mid:
https://github.com/instantinfrastructure/linux-yocto-3.10/tree/edison/arch/x86/platform/intel-mid linux-yocto-3.10/arch/x86/platform/intel-mid
I reached out to a few folks directly who's names appeared in those files but haven't heard anything.
I was informed (not by intel, but by some of the nice folks at the linux-usb list) that emailing folks in source files is a netiquette faux pas, and it was suggested I find the intel-mid platform specific mailing list.
Any clues on locating this platform/intel-mid mailing list?
Does it exist?
If not, is this forum browsed by folks that could speak to attempts to update / modify the intel-mid platform?
Highlighted
New Contributor III
Looking at all the heavy hitters on the lkml, it may be that I need to ask there directly... a bit intimidating.
But that may be the right place.
Highlighted
New Contributor III
Looks like we have two options, and I created two new threads to follow them through:
1) Using configfs with the kernel 3.19.X http://comments.gmane.org/gmane.linux.usb.general/116118 Equivalent of g_hid with configfs
2) Adding g_hid boilerplate code (from Documentation/usb/gadget_hid.txt) to the right module within the intel-mid platform by https://github.com/instantinfrastructure/linux-yocto-3.10/commit/4a7c648b3d0cf96ccaf6b6fd13357729398... adding support for usb hid gadget via a patch
Highlighted
Hi @hippiehacker
Could you tell me what kind of device you do you want to use? Have you tried to configure the device with udev, or maybe just using the kernel-module-g-multi_3.10.17+git0+6ad20f049a_c03195ed6e-r0_edison.ipk package http://alextgalileo.altervista.org/edison-package-repo-configuration-instructions.html from AlexT's repo
Highlighted
New Contributor III
As shipped with the Intel-Edison BSP kernel https://www.kernel.org/doc/Documentation/usb/gadget_multi.txt https://www.kernel.org/doc/Documentation/usb/gadget_multi.txt
only supports and exports rndis,cdc, and usb-storage to the host it is connected to on boot:
On the usb that provides power and is exported from the Intel Edison using the g_multi:
linuxdesktop-with-edison-attached# lsusb -t
|__ Port 1: Dev 87, If 0, class="Communications", Driver=rndis_host, 480M
|__ Port 1: Dev 87, If 1, class="CDC" Data, Driver=rndis_host, 480M
|__ Port 1: Dev 87, If 2, class="Communications", Driver=cdc_acm, 480M
|__ Port 1: Dev 87, If 3, class="CDC" Data, Driver=cdc_acm, 480M
|__ Port 1: Dev 87, If 4, class="Mass" Storage, Driver=usb-storage, 480M
I would like to add usbhid support to g_multi and be able to simultaneously export the above at the same time as we export a keyboard / mouse HID
linuxdesktop-with-hidpatched+edison-attached# lsusb -t
.... above plus a keyboard / mouse ...
|__ Port 1: Dev 87, If 5, class="Human" Interface Device, Driver=usbhid, 12M
|__ Port 1: Dev 87, If 6, class="Human" Interface Device, Driver=usbhid, 12M
It might be possible to hack/rebuild g_multi to support this, but it would definitely require changes to the ./drivers/usb/gadget/multi.c
Intel did that to incorporate the ethernet, maybe we just need to add the hid?:
+++ b/drivers/usb/gadget/multi.c
@@ -15,7 +15,6 @@
# include
# include
-# include
# include "u_serial.h"
# if defined USB_ETH_RNDIS
@@ -54,12 +53,6 @@ MODULE_LICENSE("GPL");
USB_GADGET_COMPOSITE_OPTIONS();
-static char ethernet_config[6];
-module_param_string(ethernet_config, ethernet_config, sizeof(ethernet_config),
- 0444);
-MODULE_PARM_DESC(ethernet_config,
- "ethernet configuration : should be cdc or rndis");
/***************************** Device Descriptor ****************************/
# define MULTI_VENDOR_NUM 0x1d6b /* Linux Foundation */
@@ -315,31 +308,13 @@ static int __ref multi_bind(struct usb_composite_dev *cdev)
device_desc.iProduct = strings_dev[USB_GADGET_PRODUCT_IDX].id;
/* register configurations */
- /* RNDIS configuration */
- if (strncmp(ethernet_config, "rndis", 5) == 0) {
- status = rndis_config_register(cdev);
- if (unlikely(status < 0))
- goto fail2;
- } else if (strncmp(ethernet_config, "cdc", 3) == 0) {
- /* CDC ECM configuration */
- status = cdc_config_register(cdev);
- goto fail2;
- } else {
- goto fail2;
- goto fail2;
+ status = rndis_config_register(cdev);
+ if (unlikely(status < 0))
+ goto fail2;
+ status = cdc_config_register(cdev);
+ goto fail2;
usb_composite_overwrite_options(cdev, &coverwrite);
/* we're done */
