Intel® Makers
9881 Discussions
Environment Variables not accessible
PReic1
Hi everyone
I'm trying to write a node.js app, which relays on some environment variables which I have put in the .bash_profile file. When I start the node.js application by command line, everything works find and the variables are readable (env.process.FOO). But when I start the app from the XDK, it seems that the app can not reach the variables.
I think the problem is, that while in cli, I'm root, whereas in the other case I'm the xdk deamon. Any ideas on how to access the environment variables even when run from the XDK?
thanks already!
jhane2
Did you try putting them in /etc/profile instead of root's profile?
jeff
PReic1
hey jhane.
thanks for the idea, sadly it didn't work. it's still the same behaviour :/
best
pascal
Carlos_M_Intel
Hi digi
Could you attached the .bash_profile file you are using?
Have you tried to put the variables in /node_app_slot?
When running from the XDK, are you receiving an error message in the log o is it just that it's not running?
Charlie
PReic1
Hey Charlie
export FOO="BAR"
This is already the whole .bash_profile file (either appended to /etc/profile or as an own file in /home/root/.bash_profile.
The logging looks like this
console.log(process.env.FOO);
If running from command line, it logs the following:
BAR
If running from the XDK
undefined
Putting the file in /.node_app_slot does not seem to work.
thanks!
regards
pascal
Matthias_H_Intel
can't reproduce - works fine for me.
have you rebooted your board after updating /etc/profile?
PReic1
multiple times
so after you put everything into /etc/profile , you just rebooted and could access it from within process.env.FOO ?
thanks!
Matthias_H_Intel
not "FOO" but console.log(process.env.NODE_PATH) which is already defined in /etc/profiles
Carlos_M_Intel
Hi digi
Did you try the same thing as mhahn? Do you still have the same problem?
Charlie
