Hi, guys,
I am building a default image for Galileo Gen 2 without any changes, exactly following the steps in the building guide, release 1.2.1.1, which I think is the newest one.
I am building a full-featured Linux for SD card, so following the Section 6 of the guide. I don't build grub and anything else, just in meta-clanton_v1.2.1.1.
After building and following the instruction, I copy the required files into a SD card. I followed the link: https://software.intel.com/en-us/get-started-galileo-linux-step1 IoT - Step 1: Make a bootable micro SD card | Intel® Software to format the SD card, so it won't be a problem.
Then I got Error 15: File not found after booting, like the image below:
At first, I build it on a Linux Mint 17.1, then I tryied Ubuntu 14.04. They all failed.
How to solve this problem?
Finally, thanks to a developer, the problem is due to grub configuration file.
grub.conf is misconfigured so that it can not load the kernel.
root=/dev/**** is not correct, then change it to the right interface according the command "lsblk", then the problem is solved.
Thanks for all your help.
Hi AU_yzy0050,
If possible I would suggest using Debian version 7 as a host for building the image, as this release has been tested on this distro. I have tried to build the image on other distros such as fedora and have encountered problems similar to yours above.
Thank you, Padraigc, I will try Debian 7.
No problem, if you encounter any more problems, please post on here again
Hello AU_yzy0050,
If you build the Yocto image basing it on Quark's BSP 1.2.1.1 ( https://downloadcenter.intel.com/download/23197/Intel-Quark-SoC-X1000-Board-Support-Package-BSP-) you don't need follow the steps in https://software.intel.com/en-us/get-started-galileo-linux-step1 as those steps are only required to boot on the eglibc image. You can simply copy the files into the SD card and it should be able to boot.
However, you will have to make sure to rename the image files correctly.
-Peter.
Yes, I did exactly as what the guide said. The error just appeared.
I think no matter Mint or Ubuntu should work. Anyway, I will try Debian 7 for sure.
Will let you know if the problem is solved.
Please check this thread.
The guy also had the same problem, but after switching to Debian 7, the problem was gone.
Now, Debian 7 is updated to 7.11. I don't if this version will work.
Hi AU_yzy0050,
I can confirm it works on Debian 7.11, that is what I am using at the moment.
Hi, Padraigc,
I just tried Debian 7.11, but I still got the problem...
What could be the possible reason for this issue? I'm frustrated now.
Before starting building, I got this error, like the thread:
ERROR: OE-core's config sanity checker detected a potential misconfiguration.
Either fix the cause of this error or at your own risk disable the checker (see sanity.conf).
Following is the list of potential problems / advisories:
TMPDIR is setgid, please don't build in a setgid directoryTMPDIR is setuid, please don't build in a setuid directory
Then I installed all suggested packages, still got the error. Then I created the file by touch conf/sanity.conf as suggested.
Could this error be the reason?
Thank you.
Hi AU_yzy0050,
Could you please check the permissions attached to your whole build directory (i.e. meta-clanton_v1...) by typing: "ls -l" in the directory above meta-clanton_v1.
I've a feeling this is a permissions issue due to this: https://www.mail-archive.com/openembedded-core@lists.openembedded.org/msg54490.html https://www.mail-archive.com/openembedded-core@lists.openembedded.org/msg54490.html
