Intel® Makers
9881 Discussions
Error compiling... trying to use the Mouse library
ARami7
Just trying to make my gen 2 'left click', tried this and it looks good but for some reason i got an error ive never seen before:
# include
void setup() {
// put your setup code here, to run once:
Mouse.begin();
Mouse.click(MOUSE_LEFT);
void loop() {
// put your main code here, to run repeatedly:
error:
\libraries\Mouse\src/Mouse.h:25:17: fatal error: HID.h: No such file or directory
compilation terminated
exit status 1
error compiling for board Intel@ Galileo Gen2.
Community Manager
Hi AdanChristo,
The libraries available for the Galileo Board are located in the location: C:\Users\"Youruser"\AppData\Local\Arduino15\packages\Intel\hardware\i586\1.6.2+1.0\libraries
The libraries for Mouse are not available for Galileo, as you know the Arduino IDE works for all the Arduino boards too so that is the reason why it comes included in the IDE. If you want to use the Arduino IDE with your Galileo Board, take a look at the available libraries.
I suggest you to always use the latest Arduino IDE version in order to have the latest updates in it.
Charlie
FTinetti
Honored Contributor I
I think it's at least difficult... but the threads I've found are a little bit old:
/thread/55283?start=0&tstart=0 https://communities.intel.com/thread/55283?start=0&tstart=0
/message/240068# 240068 https://communities.intel.com/message/240068# 240068
Community Manager
Hi AdanChristo,
Charlie
