Intel® Makers
9881 Discussions
Error handling for MRAA::I2C
TKirv1
New Contributor II
I am currently using a few i2c devices on a quadrotor which is being developed, so quite often an i2c line comes unplugged during a rough flight. Currently when this happens the program quits with the error
terminate called after throwing an instance of 'std::runtime_error'
what(): writeWord: mraa_i2c_write_word_data() failed
Aborted
which leads to the quadrotor's props spinning uncontrolled. I need the program to recognize/handle this error and continue running, so that it may safely turn off the motors. I have tried the following if statement
if( flow->readBytesReg(0x00,frame,22)==-1 || flow->readBytesReg(0x16,int_frame,25)==-1) {
kill(pwm);
exit(1);
But it seems the program is aborted before the condition is even evaluated so this does not work.
Is there a simple relatively simple way to do this?
-Thomas
Community Manager
Hello Thomas,
Thanks for reaching out!
I believe the answer to this question is simpler than one would think. I believe what you should try is to have two different scripts, the one you already have and one that starts to work whenever you have the issue described above. This second script would simply tell you quadrotor to stop (or to do some specific commands for this specific situation). The question is now, how do I start a second script when my original script crashes? Searching on the web I came across a great shell script (in http://stackoverflow.com/questions/7708715/check-if-program-is-running-with-bash-shell-script http://stackoverflow.com/questions/7708715/check-if-program-is-running-with-bash-shell-script in case you are interested) which I slightly modified. The script checks on a process (in my case called blink) and when it stops (by whatever reason), it starts a different one (in my case blink1). This is the script:
# !/bin/bash
check_process() {
echo "$ts: checking $1"
[ "$1" = "" ] && return 0
[ `pgrep -n $1` ] && return 1 || return 0
while [ 1 ]; do
# timestamp
ts=`date +%T`
echo "$ts: begin checking..."
check_process "blink"
[ $? -eq 0 ] && echo "$ts: not running, starting alternate condition..." && `./blink1` && break
sleep 5
done
***You'll need to install procps, procps-dbg, procps-dev and procps-docs in order to use pgrep, this packages can be downloaded from the official repo.
I hope this helps you. I tested it and works fantastic, let me know if you have any questions about the code and I'll gladly explain it to you.
-Peter.
Community Manager
Hello Thomas,
# !/bin/bash
check_process() {
while [ 1 ]; do
# timestamp
ts=`date +%T`
sleep 5
done
-Peter.
TKirv1
New Contributor II
Thank you Peter!
This looks like it should do the trick. I will test this as soon as possible and let you know how it goes.
-Thomas
Community Manager
I'm here to help!
Let me know how it goes.
-Peter.
TKirv1
New Contributor II
I put this to the test and it works great! Only thing left to test is to see what happens if the SCL or SDA lines controlling pwm driver itself come unplugged. I would hope the driver would stop outputting a pwm signal, though.
Thanks for your help peter,
-Thomas
Community Manager
I'm glad to hear that!
Please continue your tests and keep us updated. If you still have any issues of doubts, please don't hesitate to come back to the community, we will try to help you in any way we can.
-Peter.
TKirv1
New Contributor II
I actually have one more question: Is there a way to automatically run the script which checks on a process when that process starts?
Thomas
Community Manager
Yes, and the way to do it is easier that you would image. You can simply use a system call in you code, which I believe is written in C++, please correct me if that is wrong. The beginning of your script can look like the following:
# include
# include
using namespace std;
int main ()
cout << "Starting system check... \n";<p>  system("./system_check.sh &");
That should start your shell script alongside the C++ script.
Let me know if this helps you.
-Peter.
TKirv1
New Contributor II
That works great. Thanks again Peter for being very helpful and teaching me something new!
Cheers,
Thomas
Community Manager
I'm glad to help! Keep us updated on your projects.
-Peter.
