Intel® Makers
9881 Discussions
Error in final launch sequence Failed to execute MI command
BMist2
Hi All,
I'm keep getting this error while programming D2000 on CRB.
Can not move forward with coding as can not program the MCU through Eclipse on Win10.
Please check the Images for more info.
also this one;
Appreciate anyone know/share tweak for this?
Michelle_C_Intel
Hi ,
Can you send on the steps you took to reach this point. Does it happen every time ?
That error normally indicates an issue with the JTAG connection to the board.
In case there is a driver issue can you try re-installing the driver using the install.bat located in C:\IntelSWTools\ISSM_2016.0.0XX\tools\debugger\driver
regards,
Michelle.
BMist2
Hi Michelle,
Thank you for the reply.
I managed to fix it by installing and re-installing JavaSE.
There wasn't any problem with JTAG connections.
Best,
