Community
cancel
Showing results for
Search instead for
Did you mean:
MHila
Error installing intel MKL on Joule with Ref-OS-IoT
Jump to solution
( Running Ref-OS-IoT version 1703 )
After downloading the Linux version of MKL from:
https://software.intel.com/en-us/intel-mkl Intel® Math Kernel Library (Intel® MKL) | Intel® Software
then running the ./install.sh script this is what I get:
Initializing, please wait...
Error: not enough disk space in "/tmp" temporary directory. 100MB is
required for startup.
Press "Enter" key to quit:
However the tmp directory is almost empty at 1.9GB:
joule:~/mkl$ df -h
Filesystem Size Used Available Use% Mounted on
devtmpfs 1.9G 0 1.9G 0% /dev
/dev/disk/by-partuuid/12345678-9abc-def0-0fed-cba987654320
14.3G 7.6G 6.0G 56% /
tmpfs 1.9G 0 1.9G 0% /dev/shm
tmpfs 1.9G 17.2M 1.9G 1% /run
tmpfs 1.9G 0 1.9G 0% /sys/fs/cgroup
tmpfs 1.9G 16.0K 1.9G 0% /tmp
tmpfs 1.9G 40.0K 1.9G 0% /var/volatile
tmpfs 382.8M 0 382.8M 0% /run/user/0
tmpfs 382.8M 0 382.8M 0% /run/user/1000
Changing the used temporary directory in shell with command argument didn't help either, so:
joule:~/mkl$ mkdir /home/devel/tmp
joule:~/mkl$ ./install.sh --tmp-dir=/home/devel/tmp
same:
Error: not enough disk space in "/home/devel/tmp" temporary directory.
100MB is required for startup.
Muhammad Hilal,
Community Manager
Hi Muhammad Hilal,
I just want to inform you that the lastest BIOS 1F1 and latest Ref-OS-IoT v1704 have been released, and they support MKL.
We recommend you to upgrade them to fix the issue, we tried it and we didn't have issues installing it. You can find the latest versions here: https://software.intel.com/en-us/iot/hardware/joule/downloads
Let us know if it works for you, thank you for your patience.
Have a nice day.
Leonardo R.
Community Manager
Hi Muhammad Hilal,
Thank you for contacting us.
We will investigate more about this, and we will contact you as soon as we have updates.
We appreciate your patience.
Leonardo R.
Community Manager
Hi Muhammad Hilal,
Have a nice day.
Leonardo R.
Community Manager
Hi Muhammad Hilal,
Do you have any updates about this? Did you successfully install MKL on your Joule?
Leonardo R.
MHila
Hi Leonardo, Thanks for the follow up,,
I'm still to update to 1704, as my current work requires installing lots of dependencies manually from sources to build and run Netatalk, Caffe and other tools. I was exploring how to backup my current 1703 installation before updating just in case. I found this thread for backup:
and am trying to reproduce the steps posted by Yermi now.
In few days I expect to have updated OS and BIOS and tried install MKL again, then I shall send my experience here.
M. Hilal
Community Manager
Hi Muhammad Hilal,
Thanks for letting us know, we will wait for your results.
Have a nice day.
Leonardo R.
