Intel® Makers
9881 Discussions
Error loading kernel module fbtft (built with Yocto)
SHyme
This is a cross-post from an issue on the https://github.com/notro/fbtft/issues/353 fbtft GitHub repository, but I was wondering if anyone here has run into this issue. It seems that fbtft wants to use DMA with SPI (even though, from what I've read, the Edison does not have DMA on SPI). Is there any way to unregister the DMA mapping with SPI?
I managed to get fbtft compiled with the Edison kernel using the Yocto Project and https://github.com/wallacezq/fbtft-yocto-recipe wallacezq's recipe. I have an https://www.adafruit.com/products/358 Adafruit 1.8" LCD connected to the Edison (SPI bus 5.0). I try to load the module with
modprobe fbtft dma=0
modprobe fbtft_device name=sainsmart18 busnum=5 speed=5000000 bgr=1 gpios=reset:44,dc:45
but `dmesg` gives me the following:
[ 63.099949] fbtft_device: SPI devices registered:
[ 63.099982] fbtft_device: ads7955 spi5.0 25000kHz 16 bits mode=0x00
[ 63.100002] fbtft_device: spidev spi5.1 25000kHz 8 bits mode=0x00
[ 63.100016] fbtft_device: 'fb' Platform devices registered:
[ 63.100106] fbtft_device: Deleting spi5.0
[ 63.100904] BUG: sleeping function called from invalid context at /media/Project/Yocto/edison-src/out/linux64/build/tmp/work/edison-poky-linux/linux-yocto/3.10.17-r0/linux/mm/slub.c:926
[ 63.101049] in_atomic(): 1, irqs_disabled(): 1, pid: 292, name: modprobe
[ 63.101118] CPU: 1 PID: 292 Comm: modprobe Tainted: G O 3.10.17-yocto-standard # 5
[ 63.101133] Hardware name: Intel Corporation Merrifield/BODEGA BAY, BIOS 542 2015.01.21:18.19.48
[ 63.101147] f5640590 00000124 f5197cf0 c18ca73a f5197d14 c126d689 c1ac832c 00000001
[ 63.101202] 00000001 00000124 f5640890 f5d55284 00000000 f5197d48 c13203d9 f5197d38
[ 63.101252] c18d33bd c18cfab6 c15c7014 00000020 f5d5532c 000080d0 f5197d48 f5d55284
[ 63.101303] Call Trace:
[ 63.101342] [] dump_stack+0x16/0x18
[ 63.101371] [] __might_sleep+0xe9/0x110
[ 63.101401] [] kmem_cache_alloc_trace+0x39/0x1a0
[ 63.101429] [] ? add_preempt_count+0x7d/0xf0
[ 63.101453] [] ? _raw_spin_unlock_irqrestore+0x26/0x60
[ 63.101479] [] ? setup+0x5d4/0x840
[ 63.101504] [] setup+0x5d4/0x840
[ 63.101530] [] ? get_parent_ip+0xb/0x40
[ 63.101555] [] ? sub_preempt_count+0x95/0xf0
[ 63.101581] [] spi_setup+0x4a/0x120
[ 63.101609] [] ? klist_devices_get+0x20/0x20
[ 63.101634] [] ? bus_find_device+0x67/0x90
[ 63.101660] [] spi_add_device+0xe1/0x1d0
[ 63.101688] [] spi_new_device+0x7f/0xc0
[ 63.101725] [] fbtft_device_init+0x492/0x1000 [fbtft_device]
[ 63.101754] [] ? __vunmap+0x7c/0xf0
[ 63.101780] [] ? 0xf842bfff
[ 63.101805] [] do_one_initcall+0xaa/0x170
[ 63.101828] [] ? do_one_initcall+0xaa/0x170
[ 63.101856] [] ? set_section_ro_nx+0x54/0x59
[ 63.101885] [] load_module+0x1113/0x16c0
[ 63.101912] [] ? kernel_read+0x35/0x50
[ 63.101948] [] SyS_finit_module+0x7d/0xc0
[ 63.101975] [] ? vm_mmap_pgoff+0x7b/0xa0
[ 63.102007] [] syscall_call+0x7/0xb
[ 63.102034] spi spi5.0: setting default chip values
[ 63.102081] ------------[ cut here ]------------
[ 63.102108] WARNING: at /media/Project/Yocto/edison-src/out/linux64/build/tmp/work/edison-poky-linux/linux-yocto/3.10.17-r0/linux/kernel/softirq.c:160 local_bh_enable_ip+0x98/0xe0()
[ 63.102120] Modules linked in: fbtft_device(O+) fbtft(O) fb_sys_fops syscopyarea sysfillrect sysimgblt usb_f_acm u_serial g_multi libcomposite bcm_bt_lpm bcm4334x(O)
[ 63.102208] CPU: 1 PID: 292 Comm: modprobe Tainted: G O 3.10.17-yocto-standard # 5
[ 63.102222] Hardware name: Intel Corporation Merrifield/BODEGA BAY, BIOS 542 2015.01.21:18.19.48
[ 63.102234] c1ac6794 00000000 f5197c68 c18ca73a f5197c90 c12408be c1acfc6b c1ac6794
[ 63.102285] 000000a0 c1248c98 c1248c98 c1522eb1 00000000 f6c4b024 f5197ca0 c1240982
[ 63.102334] 00000009 00000000 f5197cac c1248c98 f6c4b0a4 f5197cb4 c18cfa7f f5197cf0
[ 63.102384] Call Trace:
[ 63.102413] [] dump_stack+0x16/0x18
[ 63.102442] [] warn_slowpath_common+0x5e/0x80
[ 63.102467] [] ? local_bh_enable_ip+0x98/0xe0
[ 63.102491] [] ? local_bh_enable_ip+0x98/0xe0
[ 63.102519] [] ? intel_mid_dma_alloc_chan_resources+0x71/0x1a0
[ 63.102545] [] warn_slowpath_null+0x22/0x30
[ 63.102570] [] local_bh_enable_ip+0x98/0xe0
[ 63.102594] [] _raw_spin_unlock_bh+0x1f/0x30
[ 63.102620] [] intel_mid_dma_alloc_chan_resources+0x71/0x1a0
[ 63.102645] [] ? klist_put+0x3a/0x90
[ 63.102672] [] dma_chan_get+0x3b/0xc0
[ 63.102697] [] __dma_request_channel+0x195/0x370
[ 63.102722] [] ? pci_get_subsys+0x38/0x40
[ 63.102745] [] ? u32_reader+0x60/0x60
[ 63.102770] [] setup+0x489/0x840
[ 63.102796] [] ? get_parent_ip+0xb/0x40
[ 63.102822] [] ? sub_preempt_count+0x95/0xf0
[ 63.102849] [] spi_setup+0x4a/0x120
[ 63.102876] [] ? klist_devices_get+0x20/0x20
[ 63.102901] [] ? bus_find_device+0x67/0x90
[ 63.102927] [] spi_add_device+0xe1/0x1d0
[ 63.102954] [] spi_new_device+0x7f/0xc0
[ 63.102990] [] fbtft_device_init+0x492/0x1000 [fbtft_device]
[ 63.103018] [] ? __vunmap+0x7c/0xf0
[ 63.103042] [] ? 0xf842bfff
[ 63.103066] [] do_one_initcall+0xaa/0x170
[ 63.103089] [] ? do_one_initcall+0xaa/0x170
[ 63.103117] [] ? set_section_ro_nx+0x54/0x59
[ 63.103145] [] load_module+0x1113/0x16c0
[ 63.103170] [] ? kernel_read+0x35/0x50
[ 63.103205] [] SyS_finit_module+0x7d/0xc0
[ 63.103232] [] ? vm_mmap_pgoff+0x7b/0xa0
[ 63.103264] [] syscall_call+0x7/0xb
[ 63.103282] ---[ end trace b72fd31158b70fba ]---
[ 63.127052] fbtft_device: GPIOS used by 'sainsmart18':
[ 63.127075] fbtft_device: 'reset' = GPIO44
[ 63.127090] fbtft_device: 'dc' = GPIO45
[ 63.127102] fbtft_device: SPI devices registered:
[ 63.127121] fbtft_device: spidev spi5.1 25000kHz 8 bits mode=0x00
[ 63.127138] fbtft_device: fb_st7735r spi5.0 5000kHz 8 bits mode=0x00
[ 63.265662] intel_mid_ssp_spi_unified 0000:00:07.1: ERROR : DMA buffers already mapped
I do not get a /dev/fb? device, so it seems the module is running into an issue with DMA buffers. As far as I can tell, between the recipe's patches and `dma=0`, I should be disabling DMA on fbtft, but it does not seem to be the case. I do not want DMA because as far as I know, the Edison does not have DMA on SPI.
How do I prevent fbtft from using DMA or unregister the DMA mapping on SPI? Any help would be appreciated!
Sergio_A_Intel
We will investigate on how to disable DMA on the Edison. We will reply back to you soon.
Sergio
Sergio_A_Intel
You can try to build a new kernel without the DMA-SPI. With this custom image you make sure the DMA is disabled.
You can also try to contact the author of the kernel module since we only support the kernel we provide in our BSP.
Sergio
SHyme
Thank you, Sergio! How do I disable DMA-SPI for the image? Is there a particular kernel option I need to turn off?
[Edit] I found one that says "DMA support for DW SPI controller on Intel Moorestown..." I'll try disabling that one.
SHyme
Sergio,
I tried disabling ""DMA support for DW SPI controller on Intel Moorestown..." and that did not seem to help. I still get "ERROR : DMA buffers already mapped" when I try to "modprobe fbtft_device." Any advice?
Thanks!
Sergio_A_Intel
How did you tried to disable "DMA support for DW SPI controller on Intel Moorestown"? The DMA module DW SPI is called SPI_DW_MID_DMA. This module depends on SPI_DW_PCI and INTEL_MID_DMAC. Remove or disabling one of these modules may be causing your error. Remember that these modifications are not supported so we can only guide you through some of the basic configuration. Maybe you can try to do into one of these files the SPI_DW_MID_DMA depends on and disable only the specific files that cause the error.
Sergio
SHyme
I was able to disable "DMA support for DW SPI controller on Intel Moorsetown" through the Yocto configuration interface:
I got the same error with and without that option enabled. I guess my problem is trying to figure out which module is causing the error. Only the modules that you mentioned seem to have anything to do with SPI DMA, but disabling them does not seem to help.
