Intel® Makers
9881 Discussions
Error on ssh connection: Error: connect ENETUNREACH
PDani3
please what do i do when i get this error while trying to establish connection between intel xdk iot and the galileo board
Sergio_A_Intel
What image are you using? Make sure you are using the latest.
What steps are you using to connect? Have you already seen this https://software.intel.com/en-us/node/564546 IoT - Connecting to your board using a serial or SSH connection | Intel® Developer Zone ?
Sergio
PDani3
yes I'm downloaded the latest image with the name: "iot-devkit-latest-mmcblkp0.direct.bz2".
If I were to follow the instructions stated in https://software.intel.com/en-us/node/564546 IoT - Connecting to your board using a serial or SSH connection | Intel® Developer Zone, will i still be able to do node.js?
Sergio_A_Intel
Yes, the latest IoT image for Galileo comes with node v0.10.35.
Download it from here: https://software.intel.com/sites/landingpage/iotdk/board-boot-image.html IoT Download - Board Boot Image
Sergio
