Intel® Makers
9868 Discussions
Error "Program "i586-intel-elfiamcu-gcc" not found in PATH"?
Community Manager
I am using Eclipse Platform Version Luna SR2 (4.4.2) on Windows 8.1 64-bit OS. The OpenOCD Session is active with "Info: JTAG tap: quark_d2000.lmt enabled".
I am getting the following errors:
Description Resource Path Location Type
Program "i586-intel-elfiamcu-gcc" not found in PATH bsp_hello_world [Discovery Options] page in project properties C/C++ Problem
Program "make" not found in PATH bsp_hello_world C/C++ Problem
I have looked at the following reference guide page but I do not know how to make any of these changes within Eclipse.
https://software.intel.com/en-us/node/604846 https://software.intel.com/en-us/node/604846
Where would I correct these errors in the project settings?
Michelle_C_Intel
You need to start eclipse using the iss_mcu_ide_eclipse-launcher.bat to configure the environment variables.
Looking at your other issue I presume this is now working for you also?
regards,
Michelle.
Michelle_C_Intel
regards,
Michelle.
Community Manager
Yes. I didn't realize that opening the Eclipse.exe executable in the folder C:\IntelSWTools\ISSM_2016.0.027\eclipse did not load the proper configuration. I will use iss_mcu_ide_eclipse-launcher.bat in the future. Thanks!
