Intel® Makers
9873 Discussions
Error trying to use Openocd with OLIMEX_ARM_USB_OCD_H and Intel Galileo Gen2
HMero
I am trying to test source level debugging with a OLimex ARM-USB-OCD-H jtag adapter and my Intel Galileo Gen 2 board but when i try to start openocd I get
openocd -f /usr/share/openocd/scripts/interface/ftdi/olimex_arm_usb_ocd_h.cfg -f /usr/share/openocd/scripts/board/quark_x10xx,board.cfg
Open On_Chip Debugger 0.8.0 (2017-06-26-22:51)
Licensed under GNU GPL v2
Info: only one transport option: autoselect 'jtag'
adapter speed: 4000 kHz
trst_only separate trst_push_pull
Info: clock speed 4000 kHz
Info: JTAG tap;quark_x10xx.cltap tap/device found 0x0e681013 (mfg:0x009,port:0xe681, ver: 0x0)
Error: quark_x10xx.cltap: IR capture error: saw 0xff not0x1
Warn: Bypassing JATG setup events due to error
Pls can you help me to solve the problem?
Best regards and thanks in advance
Community Manager
Hi HoracioMerovich,
Thank you for contacting us.
Would you please provide more information on what steps you've taken previous to using the following command:
We'd like to have more information to better diagnose your issue.
We'd also like to suggest the following links, as they provide more information on OpenOCD being run properly.
https://communities.intel.com/message/220257# 220257 https://communities.intel.com/message/220257# 220257
http://openocd.zylin.com/# /c/1829/
We'll be waiting for your response.
-Sergio A
HMero
Community Manager
Hi HoracioMerovich,
Thank you for your reply.
Did you have any difficulties following section 4 of the document you've attached? Have you followed all steps in section 4?
I've looked online at the error and found some threads with related information. They have some suggestions on several things you can try. Some of the most useful ones I found were:
https://communities.intel.com/thread/104532 https://communities.intel.com/thread/104532
https://sourceforge.net/p/openocd/mailman/message/35176487/
Please check the suggestions and let us know if this helps.
-Sergio A
Community Manager
Hi HoracioMerovich,
Do you still need assistance with this case?
-Sergio A
