Intel® Makers
9874 Discussions
Error while booting Intel Edison
VQuei1
Hi there,
I have an Intel Edison with an extension board to communicate with another device via zigbee. This week when I tried to boot the board I got some errors and after some manually reboots I'm having these messages and the board is rebooting unstoppable. I want to know what I can do to fix this.
PS: I tried to supply via USB (PC Port) and via cellphone charger.
GADGET DRIVER: usb_dnl_dfu
reading vmlinuz
5299520 bytes read in 131 ms (38.6 MiB/s)
Valid Boot Flag
Setup Size = 0x00003c00
Magic signature found
Using boot protocol version 2.0c
Linux kernel version 3.10.17-yocto-standard-r2 (root@p32mac) # 7 SMP PREEMPT Thu Feb 26 09:57:06 UTC 2015
Building boot_params at 0x00090000
Loading bzImage at address 00100000 (5284160 bytes)
Kernel command line: "root=/dev/mmcblk1p1 rootdelay=3 rootfstype=ext4 console=tt yMFD2 earlyprintk=ttyMFD2,keep loglevel=4 systemd.unit=first-install.target hard ware_id=00 g_multi.iSerialNumber=bb559091645a234f7cbbf68f3f652005 g_multi.dev_ad dr=02:00:86:65:20:05"
Starting kernel ...
[ 0.748048] pca953x 1-0020: failed reading register
[ 0.753198] pca953x 1-0021: failed reading register
[ 0.753615] pca953x 1-0022: failed reading register
[ 0.763144] pca953x 1-0023: failed reading register
[ 1.646309] pmic_ccsm pmic_ccsm: Error reading battery profile from battid fr mwrk
[ 1.654990] pmic_ccsm pmic_ccsm: Battery0 temperature inside boundary
PSH KERNEL VERSION: b0182929
WR: 20104000
SCU IPC: 0x800000d0 0xfffce92c
PSH miaHOB version: TNG.B0.VVBD.0000000c
microkernel built 10:14:01 Jan 13 2015
******* PSH loader *******
PCM page cache size = 192 KB
Cache Constraint = 0 Pages
Arming IPC driver ..
Adding page store pool ..
PagestoreAddr(IMR Start Address) = 0x04899000
pageStoreSize(IMR Size) = 0x00080000
*** Ready to receive application ***
U-Boot 2014.04 (Feb 09 2015 - 15:40:31)
Watchdog enabled
DRAM: 980.6 MiB
MMC: tangier_sdhci: 0
In: serial
Out: serial
Err: serial
Hit any key to stop autoboot: 0
Target:blank
Partitioning already done...
Flashing already done...
reading vmlinuz
Valid Boot Flag
Kernel command line: "root=/dev/mmcblk1p1 rootdelay=3 rootfstype=ext4 console=ttyMFD2 earlyprintk=ttyMFD2,keep loglevel=4 systemd.unit=first-install.target hardware_id=00 g_multi.iSerialNumber=bb559091645a234f7cbbf68f3f652005 g_multi.dev_addr=02:00:86:65:20:05"
Starting kernel ...
[ 0.748622] pca953x 1-0020: failed reading register
[ 0.753857] pca953x 1-0021: failed reading register
[ 0.754263] pca953x 1-0022: failed reading register
[ 0.763791] pca953x 1-0023: failed reading register
[ 1.656708] pmic_ccsm pmic_ccsm: Error reading battery profile from battid frmwrk
[ 1.665690] pmic_ccsm pmic_ccsm: Battery0 temperature inside boundary
[ 1.674009] pmic_ccsm pmic_ccsm: Battery0 temperature inside boundary
Community Manager
Hi FocaaBR,
Thanks for your interest in the Intel® Edison™ Platform.
I'm sorry to hear that your Edison isn't booting correctly. Have you tried to re-flash your image?
Please let me know if this fixes your issue, have a nice day!
-Jose P.
VQuei1
Hi there,
I did not try to re-flash the image. Could you please send me a link that explain how to do that (Of course I will search about it but it would be perfect to compare infos). Right now I'm using the Edison in a custom PCB that fit my needs for my project and I'm using an ublinux image to boot from a SD card. So the process should be to re-flash the ublinux image and leave the SD with the data or should I remake all?
Thank you.
Community Manager
Hi FocaaBR,
Re-flash means to flash again your image, here is the procedure with the Yocto image: https://software.intel.com/en-us/flashing-the-firmware-on-intel-edison-board IoT - Flashing your firmware manually | Intel® Software . Unfortunately, I don't have too much experience with Ubilinux, since we handle issues with the Yocto image. I think that in here https://emutex.com/products/ubilinux Emutex - ubilinux they might be able to help you further.
-Jose P.
