Intel® Makers
9872 Discussions
Ethernet EGLIBC image
BWill15
New Contributor II
My ethernet doesn't work on the http://downloadmirror.intel.com/25384/eng/iot-devkit-201510010757-mmcblkp0-galileo.direct.xz EGLIBC microSD card image (210 MB) of https://software.intel.com/en-us/iot/hardware/galileo/downloads IoT - Intel® Galileo Board Download | Intel® Developer Zone.
There is no resolf.conf file in my etc/network.
root@galileo:/etc/network# ls
if-down.d if-post-down.d if-pre-up.d
Sergio_A_Intel
With the eglibc image you can connect through Ethernet using connman. First, start and enable connman using:
systemctl start connman
systemctl enable connman
Now, with the Ethernet cable connected run the command connmanctl services, you should see the Ethernet option as AO Wired Ethernet and a number.
You can connect to this interface using connmanctl connect ethernet_# _cable.
Additionally you can configure the IP address of the interface with:
connmanctl config --ipv4 manual . The <> brackets are not needed.
More information of different connman settings in https://wiki.archlinux.org/index.php/Connman https://wiki.archlinux.org/index.php/Connman
Sergio
Sergio_A_Intel
Sergio
