Intel® Makers
9882 Discussions
Example Error "Iotkit"
yyavu
Example Error Iotkit
Error Message :
Arduino: 1.6.7 (Windows 10), Board: "Intel® Edison"
Unable to find C:\Users\DELL\Documents\Arduino\libraries\IoTkit\examples\IoTKitActuationExample\IoTKitActuationExam... in C:\Users\DELL\Documents\Arduino\libraries\IoTkit\examples\IoTKitActuationExample
Error compiling.
This report would have more information with
"Show verbose output during compilation"
enabled in File > Preferences.
yyavu
I have tried many methods. I found the solution. I deleted new Arduino release. Now it is running smoothly.
Carlos_M_Intel
Hi mekatronik,
Did you check the location C:\Users\DELL\Documents\Arduino\libraries\IoTkit\examples\IoTKitActuationExample?
I'm guessing that you are including a third party library, is this right? If you are doing this, which steps did you follow and could you post a link to the place from where you are downloading it?
Charlie
yyavu
Yes I checked.
I downloaded from here
https://github.com/enableiot/iotkit-samples/tree/master/arduino iotkit-samples/arduino at master · enableiot/iotkit-samples · GitHub
Carlos_M_Intel
Hi mekatronik,
The https://github.com/enableiot/iotkit-samples/tree/master/arduino/IoTkit IoTkit folder must be placed in the following location:
C:\Users\You\AppData\Local\Arduino15\packages\Intel\hardware\i686\1.6.2+1.0\libraries\
Once you have the IoTkit folder in there you should be able to use the library, if you have the folder there and still have problems while compiling the code, go to C:\Users\You\Documents\Arduino\libraries and delete the folder and content of \IoTkit
Let me know if this works for you.
Charlie
Carlos_M_Intel
Hi mekatronik,
I would like to know if you are adding the library as I mentioned in the post above or if you are doing this in a different way.
Kind regards,
Charlie
yyavu
yyavu
Hi again
I get iot kit error again. I have reinstalled the Windows system. reinstalled drivers and arduino. But not working arduino iot kit. Help me please
Carlos_M_Intel
Hi mekatronik,
Are you having the same error message? If there is a different one, please post it here.
Did you delete the folder ..\Documents\Arduino\libraries\IoTkit?
Where are you placing the files for the library and which Arduino IDE version are you using?
Charlie
yyavu
I deleted but I get error
Error message:
Arduino:1.6.5 (Windows 8.1), Kart:"Intel® Edison"
i586-poky-linux-g++: error: C:\Users\DELL\AppData\Local\Temp\build5228842203334704066.tmp/core.a: No such file or directory
Multiple libraries were found for "Ethernet.h"
Used: C:\Users\DELL\AppData\Roaming\Arduino15\packages\Intel\hardware\i686\1.6.7+1.0\libraries\Ethernet
Not used: C:\Intel\arduino-1.6.5\libraries\Ethernet
Carlos_M_Intel
Hi mekatronik,
I suggest you to install the https://www.arduino.cc/en/Main/Software latest Arduino IDE, V1.6.8. I know you downgrade the version you were using from 1.6.7 to 1.6.5. But you can try with the latest one.
One thing you can do is adding a copy of Ethernet.h and Ethernet.cpp in the IoTkit folder. If the problem is a conflict between the name of the libraries you can:
1. Change the name of the library
2. Delete the Ethernet library located in C:\Intel\arduino-1.6.5\libraries\Ethernet. In case you will not use this one.
Charlie
yyavu
I installed Arduino 1.6.8. it's working anymore. Thank you
