Community
cancel
Showing results for
Search instead for
Did you mean:
DPose
New Contributor II
Exposing ttyS1 on the Arduino header
Has anyone managed to expose UART1 (ttyS1) on the Arduino header? Brenndan arfoll suggested writing a logic '1' to raw gpio76/77 which I tried, but apparently that isn't enough. That guy is busy so instead of hounding him on github I thought I would see if anyone here has tried it with success.
I have a bit of test code that uses termios to setup and read/write to the port and it works fine with the default mapping. I just 'systemctl stop serial-getty@ttyS1.service' and jump rx/tx at the ftdi header. Then I can write out to the port and read it right back. All good. But if I set gpio76/77 high and move the jumper to pins 2&3 of the Arduino header I get nothing. Is other chicanery required?
Thanx,
Dallas
DPose
New Contributor II
Ok using Brendan's suggestion and information from this thread SpiderKenny I convinced myself that indeed gpio76 and gpio77 do in fact control the output of MUX9 (TX1) and MUX10 (RX1) respectively and that a '1' would select the proper input signals However I can write a 1 to both those pins all day long and it still doesn't seem to work. The UART keeps talking on the FTDI header but nothing at IO2/IO3.
Here is what I'm doing
bool mapUART1()
bool mapGOOD = true;
mraa_result_t result;
mraa_gpio_context gpio76; // UART1 TX Pin MUX
mraa_gpio_context gpio77; // UART1 RX Pin MUX
gpio76 = mraa_gpio_init_raw(76);
gpio77 = mraa_gpio_init_raw(77);
if (gpio76 == NULL || gpio77 == NULL)
syslog (LOG_DEBUG, "Couldn't get raw context");
return (false);
if (
((result = mraa_gpio_write (gpio76, 1)) != MRAA_SUCCESS)
((result = mraa_gpio_write (gpio77, 1)) != MRAA_SUCCESS)
syslog (LOG_DEBUG, "Couldn't set raw value");
mapGOOD = false;
mraa_gpio_close (gpio76);
mraa_gpio_close (gpio77);
return (mapGOOD);
I call this then setup termios as usual for /dev/ttys1 and just start sending an uppercase 'U' in a loop. Comes out on the FTDI header as I said but not IO3 as it should.
If go look at /sys/class/gpio/gpio77/value it is '1' Same for gpio76.
So what am I doing wrong? arfoll, AlexT_Intel, CMata_Intel, SpiderKenny anybody?
Brendan_L_Intel
I've replied on https://github.com/intel-iot-devkit/mraa/issues/244 mraa_uart_init(1) on galileo returns NULL and syslogs "uart: platform has only 1" · Issue # 244 · intel-iot-devkit/mraa ·… but for the sake of clarity - you also need to pin pin16 OUT LOW and pin17 OUT HIGH.
Carlos_M_Intel
Hi xthunderheartx,
Do you have updates in this? Did you try with the suggestions above?
Charlie
DPose
New Contributor II
Yeah Charlie, Brendan sorted me out, I was just too wound-up to see it! Man I need to get out of this room ... I don't even know what day it is! I'll post an example as soon as I can learn to actually follow directions and make it work.
DPose
New Contributor II
Thanks to Brendan arfoll I got this to work. This test code ignores results so needs be fixed for that of course. Thanx for your patience Brendan! Jeff jlengel might be interested.
bool mapUART1()
mraa_gpio_context gpio16; // IO3 level shifter
mraa_gpio_context gpio17; // IO3 pullup
// First, set the Level/Pullup mode for IO3/TX
gpio16 = mraa_gpio_init_raw (16); // TX Level Shifter
mraa_gpio_dir (gpio16, MRAA_GPIO_OUT); // direction to OUT
mraa_gpio_write (gpio16, 0); // Enable /(U26.4) I think
gpio17 = mraa_gpio_init_raw (17); // TX Pull UP/DOWN
mraa_gpio_dir (gpio17, MRAA_GPIO_OUT); // direction to OUT
mraa_gpio_write (gpio17, 1); // HIGH to pull up
// Now select the alternate inputs on MUX9 (TX) and MUX10. The direction
// on these pins is fixed (OUT only).
// IO3/TX
mraa_gpio_write (gpio76, 1); // Galileo U4.16(MUX9_SEL) to HIGH
// IO2/RX
mraa_gpio_write (gpio77, 1); // Galileo U4.17(MUX10_SEL) to HIGH
// You're in business. Clean up
mraa_gpio_close (gpio16);
mraa_gpio_close (gpio17);
return (mapGOOD);
