Intel® Makers
9881 Discussions
External interrupt has no effect
dnick1
I'm a beginner to arduino, using intel edison to experiment arduino programs. While i was enjoying interrupt programs, i ran into a problem. I'm not sure what is the reason behind this problem.
Here is my code:
//Pin numbers
int red = 7;
int yellow = 8;
int green = 9;
//For giving delay
int stop = 6;
int yield = 2;
int go = 6;
void setup()
Serial.begin(9600);
pinMode(red, OUTPUT);
pinMode(yellow, OUTPUT);
pinMode(green, OUTPUT);
pinMode(13, OUTPUT);
digitalWrite(red, LOW);
digitalWrite(yellow, LOW);
digitalWrite(green, LOW);
digitalWrite(13, LOW);
attachInterrupt(0,changeTime,FALLING);
void loop()
stopLight(stop);
yieldLight(yield);
goLight(go);
void stopLight(int time)
digitalWrite(red, HIGH);
Serial.println("Light mode: Stop");
delay(time * 1000);
void yieldLight(int time)
digitalWrite(yellow, HIGH);
Serial.println("Light mode: Yield");
delay(time * 1000);
void goLight(int time)
digitalWrite(green, HIGH);
Serial.print("Light mode: Go - ");
Serial.println(time);
delay(time * 1000);
void changeTime()
if(go == 6)
go = 10;
digitalWrite(13,HIGH);
else
go = 6;
digitalWrite(13,LOW);
When i give an interrupt the value of "go" doesn't change and the led on pin 13 keeps glowing except at the instance when i give the interrupt.
Is there any problem with my code or does the external interrupt work in a different way?
Diego_V_Intel
Hi danush,
I tested your code and I didn't have problems in turning ON/OFF the LED. I recommend you to try the following example code to check if the attachInterrupt() method works as you expect it to.
int pin = 13;
volatile int state = LOW;
void setup()
pinMode(pin, OUTPUT);
// Use the modes CHANGE, RISING or FALLING
attachInterrupt(2, blink, CHANGE);
void loop()
digitalWrite(pin, state);
void blink()
state = !state;
// After the ISR ends, the code in the loop will be executed as usual
Diego
Diego_V_Intel
Hi danush,
int pin = 13;
void setup()
void loop()
void blink()
state = !state;
Diego
