Intel® Makers
9881 Discussions
External power supply for Edison
AKriv
I have some problems with powering Intel Edison with breakout board. Everything works OK when I power using USB, but I can't get it to work with external power supply. I tried two power adapters (9V and 12V, both 1500mA) but Edison simply does not respond - it is not accessible through serial port and diodes are turned off. Note that I checked power adapter and wires - I used voltmeter on bottom of J21 pins and I also checked polarity (ground is closer to the edge). I don't use any battery, I left original jumper on J1, J2 is not connected to anything and power adapter is connected to J21.
I am mostly asking whether there is something obvious I've missed, or something else I could try before concluding it is some harware problem...
Thanks for any advice.
Community Manager
Hello alkri,
Thanks for reaching out!
The power supplies you used should work with the mini breakout board, and as you mentioned, in J21, the ground is closer to the edge as can be appreciated on Figure 2 of the Hardware Guide ( http://www.intel.com/content/www/us/en/support/boards-and-kits/000005574.html). So, the steps you have taken sound fine. I would like to see how you are connecting the board to the power supply, could you please send us a picture of this?
Also, if you have access to an Arduino expansion board or a different mini breakout board, could you please test powering the board on a different expansion board? If so, let us know how it goes.
Pedro M.
Community Manager
Hello alkri,
Do you have any updates about this?
Pedro M.
AKriv
sorry for late answer, I haven't worked on this project last two weeks due to my work and I kind of forget about my question here.
In the end, it was combination of bad luck and my mistakes - the first adapter I tried was not working properly and didn't provide enough current. The second was OK, but I forgot to check polarity on the second one (I checked it only with the first one, the second had the same colors of wires as the first one but polarity was actually reversed). Once I switched polarity and used second, properly working 9V adapter, everything was working OK.
A.
Community Manager
That is great news, I'm glad to hear that you are now able to use your board normally.
If you ever have any other doubt or question, please don't hesitate to come back to the community. We'll try to help you in any way we can.
Pedro M.
