Intel® Makers
9881 Discussions
F2, F7 keys do not work on boot
GHyma
I want to change some settings in BIOS but the computer does not respond to the F2 and F7 keys. I have a keyboard plugged directly into the Compute Stick USB port it works perfectly once Windows 10 is loaded but seems to not work in the initial boot up. I have tried various keyborads.
BPetr
Shoutdown pc and press power button for 3 seconds and will work.
GHyma
Thanks bok27, worked like a charm!
Anonymous
Not applicable
Hi All,
Please verify if Boot Display options in the BIOS are enable. I suggest you to keep tapping F2 or F7 since you press and release the power button.
Mike C
AKriz
Sometimes you have to be very quick and get it at the right time of the boot-up. But a working keyboard, make sure F2 and F7 are functional, plugged into the USB should work.
