Community
cancel
Showing results for
Search instead for
Did you mean:
Community Manager
[FAILED] Failed to start Hostname Service.
When I make connection to Intel Edison board through putty,
by monitoring booting sequence, I observed following service to be failed.
[FAILED]Failed to start Hostname Service.
Please let me know if why is it happening and how to start the same.
Thanks in Advance,
Amit Amrutkar
Community Manager
Hello mailto:Amit.Amrutkar88@gmail.com Amit.Amrutkar88@gmail.com,
I can see in your screenshot that you are on a older version of Edison's image. If you flash the latest version of the image (which can be found in https://software.intel.com/en-us/iot/hardware/edison/downloads https://software.intel.com/en-us/iot/hardware/edison/downloads) it is very probable that the issue will be resolved.
If for some reason you can't flash the Edison, I'd suggest you to try something like the guide found in http://www.howtogeek.com/50631/how-to-change-your-linux-hostname-without-rebooting/ http://www.howtogeek.com/50631/how-to-change-your-linux-hostname-without-rebooting/.
Let me know if this information helps you.
Peter.
Community Manager
Did flashing the board to the latest version of the image fix the issue?
Peter.
