Community
cancel
Showing results for
Search instead for
Did you mean:
OZhu
FFT library for NanoCurie Arduino 101
Are there any FFT library that I can use to run on the ARC core to do some processing on the accelerometer?
Tags (1)
Community Manager
Hello Ooi,
Thanks for reaching out!
Are you referring to fast Fourier transform? If so, is an Arduino FFT library what you are looking for? If so, does this library work: https://github.com/t3db0t/Deconspectrum/tree/master/software/PlainFFT?
I found on an Arduino forum ( https://forum.arduino.cc/index.php?topic=409791.0) that this library does work with the 101, therefore, it should also work on a CurieNano, since as it is stated by its manufacturer ( https://www.dfrobot.com/product-1537.html), it is the same hardware but mini.
I hope this information helps you,
Pedro M.
Community Manager
Hello Ooi,
Do you have any updates about this?
Pedro M.
