Intel® Makers
9881 Discussions
Failed to fetch libwebsockets
Community Manager
As title,
I'm making image on ubuntu 12.04 and got an error which is fetch libwebsockets failed.
Could someone give me direction ?
ERROR: Fetcher failure: Fetch command failed with exit code 4, output:
OpenSSL: error:14077410:SSL routines:SSL23_GET_SERVER_HELLO:sslv3 alert handshake failure
Unable to establish SSL connection.
ERROR: Function failed: Fetcher failure for URL: ' http://git.libwebsockets.org/cgi-bin/cgit/libwebsockets/snapshot/libwebsockets-1.23-chrome32-f
irefox24.tar.gz'. Unable to fetch URL from any source.
ERROR: Logfile of failure stored in: /home/xxxxx/bsp/edison-src/build/tmp/work/core2-32-poky-linux/libwebsockets/1.23-r0/temp/log.do_fetch.5027
ERROR: Task 520 (/home/xxxxx/bsp/edison-src/device-software/meta-edison-distro/recipes-connectivity/libwebsockets/libwebsockets_1.23.bb, do_fe
tch). failed with exit code '1'
Community Manager
Hello Minyuan,
Which version of the BSP are you using? We would like to see if we could replicate the issue. Nevertheless, these issues tend to happen on outdated versions. So, I'd suggest you to try with the latest version of the source which can be found in http://iotdk.intel.com/src/3.5/edison/.
-Peter.
Community Manager
Hello Minyuan,
-Peter.
Community Manager
Hi Peter,
I've downloaded the latest source and bitbake completed. Thanks for your information.@
Community Manager
Hi Minyuan,
I'm glad to hear that! If you ever have any other issues, please don't hesitate to come back to the community, we'll try to help you in any way we can.
-Peter.
