Failed to load Kernel modules during flash the device, how do I recover to a stable image?
Venkat
Was able to see my new Edison as another drive once (Windows 10, 64bit ).
Documentation suggested that I "Run Setup Tool" - https://software.intel.com/en-us/get-started-edison-windows-step2 IoT - Step 2: Run Setup Tool | Intel® Software
Set up tool failed to flash the device and suggested I flash manually.
flashall.bat from Widows command window failed.
Tried Intel Phone Flash Tool Light 5.2.4.0
Goes file till 71%, and waiting for the board to come up and times out and puts out failed messages.
On Console first set of Failures are :
Starting kernel ...
[ 0.769026] pca953x 1-0020: failed reading register
[ 0.772762] pca953x 1-0021: failed reading register
[ 0.778713] pca953x 1-0022: failed reading register
[ 0.779094] pca953x 1-0023: failed reading register
[ 1.645909] pmic_ccsm pmic_ccsm: Error reading battery profile from battid frmwrk
[ 1.654884] pmic_ccsm pmic_ccsm: Battery Over heat exception
[ 1.664510] pmic_ccsm pmic_ccsm: Battery0 temperature outside boundary
Then the second Failure is:
[ OK ] Started Apply Kernel Variables.
[FAILED] Failed to start Load Kernel Modules.
See 'systemctl status systemd-modules-load.service' for details.
Third:
OK ] Reached target Bluetooth.
[FAILED] Failed to start Hostname Service.
See 'systemctl status systemd-hostnamed.service' for details.
I am sure it is in bad state by then on the board.
On the Tool the error is:
05/15/16 09:27:29.738 INFO : [Port 1/2] Command `Sleeping for 5 seconds` succeed
05/15/16 09:27:29.738 INFO : [Port 1/2] Running `Wait for device with status pos on port 1/2` command
05/15/16 09:29:09.738 ERROR : [Port 1/2] Command `Wait for device with status pos on port 1/2` failed
05/15/16 09:29:09.738 ERROR : [Port 1/2] Flash failed (Command type: Device enumeration)
Hello Trinity,
If you have already tried to recover your board using flashall and Flash Tool Lite, then there's a last option, you could try to recover your board with Flashall.sh and pre-built xFSTK. You can find how to do it in https://communities.intel.com/thread/56133?tstart=0 https://communities.intel.com/thread/56133?tstart=0.
Try it and let me know how it goes.
Peter.
Hello Trinity,
Do you still need help? Were you able to recover your board using the Flashall.sh and pre-built xFSTK method?
Peter.
Tried with Ubintu on VirtualBox. As my Windows is not detecting the Edison board on my USB port, not sure how Ubuntu will on the Virtual Box connects to it, but tried the steps in the link any way.
Few things are different from the link with the suggested solution: Can't cd toFlash and the install.sh did not support -b
Here is the log:
mailto:venkat@venkat-VirtualBox:~/Edison/iot-devkit-prof-dev-image-edison-20160315$ venkat@venkat-VirtualBox:~/Edison/iot-devkit-prof-dev-image-edison-20160315$ sudo ./flashall.sh
Using U-Boot target: edison-blankcdc
Now waiting for dfu device 8087:0a99
Please plug and reboot the board
Timed out while waiting for dfu device 8087:0a99
DEBUG: lsusb
Bus 001 Device 003: ID 8087:0a2a Intel Corp.
Bus 001 Device 002: ID 80ee:0021 VirtualBox USB Tablet
Bus 001 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
DEBUG: dfu-util -l
dfu-util 0.5
(C) 2005-2008 by Weston Schmidt, Harald Welte and OpenMoko Inc.
(C) 2010-2011 Tormod Volden (DfuSe support)
This program is Free Software and has ABSOLUTELY NO WARRANTY
dfu-util does currently only support DFU version 1.0
Did you plug and reboot your board?
If yes, please try a recovery by calling this script with the --recovery option
mailto:venkat@venkat-VirtualBox:~/Edison/iot-devkit-prof-dev-image-edison-20160315$ venkat@venkat-VirtualBox:~/Edison/iot-devkit-prof-dev-image-edison-20160315$ sudo ./flashall.sh --recovery
Starting Recovery mode
Flashing IFWI
./flashall.sh: line 94: /usr/bin/xfstk-dldr-solo: No such file or directory
Xfstk tool error
DEBUG: lsusb
DEBUG: dfu-util -l
dfu-util 0.5
Tried the whole thing again On Ubuntu on Virtual Box. Failed to dpkg xfstk. with the following error:
mailto:venkat@venkat-VirtualBox:~/Edison/iot-devkit-prof-dev-image-edison-20160315$ venkat@venkat-VirtualBox:~/Edison/iot-devkit-prof-dev-image-edison-20160315$ sudo dpkg -i xfstk-downloader_1.7.2_all.deb
[sudo] password for venkat:
(Reading database ... 166064 files and directories currently installed.)
Preparing to unpack xfstk-downloader_1.7.2_all.deb ...
Unpacking xfstk-downloader (0.0.0) over (0.0.0) ...
Setting up xfstk-downloader (0.0.0) ...
udev start/running, process 2397
udev start/running, process 2402
Processing triggers for doc-base (0.10.5) ...
Processing 1 changed doc-base file...
Error in `/usr/share/doc-base/xfstk-downloader', line 20: all `Format' sections are invalid.
Note: `install-docs --verbose --check file_name' may give more details about the above error.
Processing triggers for gnome-menus (3.10.1-0ubuntu2) ...
Processing triggers for desktop-file-utils (0.22-1ubuntu1) ...
Processing triggers for bamfdaemon (0.5.1+14.04.20140409-0ubuntu1) ...
Rebuilding /usr/share/applications/bamf-2.index...
Processing triggers for mime-support (3.54ubuntu1.1) ...
Processing triggers for libc-bin (2.19-0ubuntu6.7) ...
Tried Ubuntu 32bit on a USB stick as the link suggested. No luck in making it work.
I tried every combination of Windows, set up tool, the lite tool, Ubuntu 64 bit on Virtual box and Ubuntu 32bit on a USB.
Flash.log :
** Flashing Edison Board Sat May 28 21:08:26 UTC 2016 **
Cannot open device
dfu-util 0.5
Filter on vendor = 0x8087 product = 0x0a99
Opening DFU USB device... Cannot open device
dfu-util 0.5
I thought everything is fine based on this console log from Ubuntu 32 bit on a USB stick. Edison board is in the same shape with same serious failures during the boot, cant load kernel etc. as in the original post:
mailto:ubuntu@ubuntu:~/Edison/iot-devkit-prof-dev-image-edison-20160315$ ubuntu@ubuntu:~/Edison/iot-devkit-prof-dev-image-edison-20160315$ ./flashall.sh
Flashing IFWI
Flashing U-Boot
Flashing U-Boot Environment
Flashing U-Boot Environment Backup
Rebooting to apply partition changes
Flashing boot partition (kernel)
Flashing rootfs, (it can take up to 5 minutes... Please be patient)
Rebooting
U-boot & Kernel System Flash Success...
Your board needs to reboot to complete the flashing procedure, please do not unplug it for 2 minutes.
dpks of xfstk is always giving the same error on both Ubuntu64 on Virtual box and Ubuntu 32 on USP stick:
mailto:ubuntu@ubuntu:~/Edison/iot-devkit-prof-dev-image-edison-20160315$ ubuntu@ubuntu:~/Edison/iot-devkit-prof-dev-image-edison-20160315$ sudo dpkg -i xfstk-downloader_1.7.2_all.deb
(Reading database ... 176059 files and directories currently installed.)
udev start/running, process 4437
udev start/running, process 4442
mailto:ubuntu@ubuntu:~/Edison/iot-devkit-prof-dev-image-edison-20160315$ ubuntu@ubuntu:~/Edison/iot-devkit-prof-dev-image-edison-20160315$ uname -a
Linux ubuntu 4.2.0-27-generic # 32~14.04.1-Ubuntu SMP Fri Jan 22 15:32:27 UTC 2016 i686 i686 i686 GNU/Linux
Hi Trinity,
I would like to have some more information about the issue. Some more details about it, could you please answer the following questions?
- Is this happening since the first time you used the board? Or have you been able to use this port before?
- On Windows, are you able to see something on the Device Manager related to the device? Maybe in "Other Devices".
- Are you using the Breakout Board or the Arduino Expansion Board?
- How are you powering your Edison, via USB only or with an external power supply? I'm wondering if this could also be a lack of power issue.
- When you tried to connect your Edison using the Virtual Machine, did it get recognized by the OS? I'm not clear about this.
- Have you tried using different USB cables? Some USB cables are not supposed to be used to connect devices to your computer e.g: the ones for rechargeable batteries and such.
Pablo
- I saw the board as a new drive next to c: only once, the very first time.
- Under device manager, under Intel SOC, I see DnX USB driver always. When
- It is a 2"x1" Intel Edison mini break out kit, has no dedicated power, no
- This board has no dedicated power, same cable for power and data. I used
- I tried from Windows, Ubuntu 64 on Virtual box, Ubuntu 32 on a USB stick.
- Using latest SAMSUNG phone charging cable that is used for data transfer
Starting kernel ...
[ 0.766763] pca953x 1-0020: failed
reading register
[ 0.772017] pca953x 1-0021: failed
reading register
[ 0.777079] pca953x 1-0022: failed
reading register
[ 0.782195] pca953x 1-0023: failed
reading register
[ 1.675739] pmic_ccsm pmic_ccsm:
[ 1.684251] pmic_ccsm pmic_ccsm:
Welcome to Linux!
Hi Trinity,
I believe there might be an issue with your board. We would like to take a closer look at your case, so I would like to ask you to submit an email to this form: https://customercare.intel.com/?lang=en-US. In the email's description, please explain everything you've tried so far, we will reply to your email as soon as possible.
Peter.
I do not know what else I could add other than what is in this thread. This already has what I tried in order with all the logs. I could cut and paste the same in to a case.
Hi Trinity,
Yes, you can put a link to this thread and mention that I recommended you to submit the email. We should be able to help you if you make an inquiry from the form I posted above.
Peter.
