Intel® Makers
9868 Discussions
Fallback option does not work on grub
Community Manager
Hello everyone;
We are looking for fail-safe boot-up strategy for our product based on Intel quark.We have been use the "meta-intel-quark" meta-layer for grub.
Now we are adding the "fallback" option in "grub.conf" file as below;
default saved
timeout 10
fallback 1
color white/blue white/cyan
title Quark X1000 First-kernel-MassStorage initrd-MassStorage RootFS-MassStorage IMR-On IO-APIC/HPET NoEMU debug
root (hd0,0)
kernel /bzImage root=/dev/ram0 console=ttyS1,115200n8 earlycon=uart8250,mmio32,$EARLY_CON_ADDR_REPLACE,115200n8 reboot=efi,warm apic=debug rw LABEL=boot debugshell=5 rootimage=image-full-quark.ext3
initrd /core-image-minimal-initramfs-quark.cpio.gz
savedefault fallback
title Quark X1000 second-kernel-MassStorage initrd-MassStorage RootFS-MassStorage IMR-On IO-APIC/HPET NoEMU debug
root (hd0,1)
But after added this option board is not boot and it show the error message as below:
Error 15: File not found
Quark GRUB Recovery shell
[ Minimal BASH-like line editing is supported. For the first word, TAB
lists possible command completions. Anywhere else TAB lists the possible
completions of a device/filename.]
grub>
Please provide us the support to solve this issue as soon as possible.
Thanks in advance
Shah_Intel
We are in progress on investigating.
Thank you,
Intel Customer Support
Shah_Intel
To inform you, we are still trying to resolved this issue on our side.
Thank you,
Shah_Intel
Hi Nikunj,
May I know, do you able to boot to partition root (hd0,1) ?
This is other partition on the same device.
It is mean, your device has 2 partitions. (hd0,0) and (hd0,1) have 2 separate systems.
Do you try to set (hd0.1) as your second devices? Could be you have two USB or SDCARD?
Community Manager
Hello mohamedshaharris;
Thanks for your reply and sorry for late Reply.
We are able to boot the partition root(hd0,1).
We had been created the second partition on sdcard for backup. We are using only sdcard not USB.
Thanks and best regards;
Nikunj Patel
Shah_Intel
Hi Nikunj,
Do you still see the "Error 15: File not found"?
Since you mention you were able to boot the partition root(hd0,1).
Community Manager
We are currently not use the savedefault fallback option so we don't have "Error 15: File not found" Error. but we need to use the savedefault fallback option in our product. whenever we use this option in our grub.conf file we found "Error 15: File not found" Error.
Nikunj Patel
