Community
cancel
Showing results for
Search instead for
Did you mean:
Highlighted
File name too long
Jump to solution
Hello All,
Getting an error File name to long for destination error on a Windows 7 installation. Intel_Galileo_Arduino_SW_1.5.3_on_Windows_v0.7.5. Any suggestions?
KLB
Accepted Solutions
Highlighted
Re: File name too long
Jump to solution
Hi KLB,
When unzipping the file "Intel_Galileo_Arduino_SW_1.5.3_on_Windows_v0.7.5.zip" extract the folder to your C:\ directory.
Intel_JEspinoza
Highlighted
Jump to solution
I renamed my zip file "g.zip" and then extracted it.
Long path names are a pain.
Highlighted
Jump to solution
Hi KLB,
Intel_JEspinoza
Highlighted
Jump to solution
hello
you are welcome
Error file name to long can be solved by using long path tool.
Highlighted
Jump to solution
I suggest you try Long path tool is the very good program for easily delete, copy & rename long path files, error, unlock solution.
Try it and solve your problem. - ( Fred Davis )
