Community
cancel
Showing results for
Search instead for
Did you mean:
CChri35
New Contributor II
Find corresponding Port tty* to COM Port X in Windows
Jump to solution
Hi!
I'm trying to realize a communication over the virtual COM Port of the Edison. On the Edison
im going to run a program that should receive the coommands sent over the virtual COM Port.
I have a windows tool which sends strings onto the COM Port that is named "Intel Edison virtual
COM Port".
But which on in the "/dev" dir is the correspondig one an how can I test it?
These are the devices:
root@edison:/dev# ls
autofs mmcblk0p6 tty12 tty54
block mmcblk0p7 tty13 tty55
char mmcblk0p8 tty14 tty56
console mmcblk0p9 tty15 tty57
cpu mmcblk0rpmb tty16 tty58
cpu_dma_latency mqueue tty17 tty59
disk net tty18 tty6
fd network_latency tty19 tty60
full network_throughput tty2 tty61
fuse null tty20 tty62
i2c-1 nvram tty21 tty63
i2c-2 port tty22 tty7
i2c-3 pti tty23 tty8
i2c-4 ptmx tty24 tty9
i2c-5 pts tty25 ttyGS0
i2c-6 ram0 tty26 ttyMFD0
i2c-7 ram1 tty27 ttyMFD1
iio:device0 ram10 tty28 ttyMFD2
iio:device1 ram11 tty29 ttyPTI0
initctl ram12 tty3 ttyPTI1
input ram13 tty30 ttymcu0
intel_sst_ctrl ram14 tty31 ttymcu1
kmem ram15 tty32 ttymcu2
kmsg ram2 tty33 uhid
log ram3 tty34 uinput
loop-control ram4 tty35 urandom
loop0 ram5 tty36 usbmon0
loop1 ram6 tty37 vcs
loop2 ram7 tty38 vcs1
loop3 ram8 tty39 vcs2
loop4 ram9 tty4 vcs3
loop5 random tty40 vcs4
loop6 rfkill tty41 vcs5
loop7 rtc tty42 vcs6
mcelog rtc0 tty43 vcsa
mem shm tty44 vcsa1
mid_ipc snd tty45 vcsa2
mmcblk0 spidev5.1 tty46 vcsa3
mmcblk0boot0 stderr tty47 vcsa4
mmcblk0boot1 stdin tty48 vcsa5
mmcblk0p1 stdout tty49 vcsa6
mmcblk0p10 tty tty5 vga_arbiter
mmcblk0p2 tty0 tty50 watchdog
mmcblk0p3 tty1 tty51 zero
mmcblk0p4 tty10 tty52
mmcblk0p5 tty11 tty53
Tags (1)
Pablo_M_Intel
Hi Christoph.P,
The device that you should be looking at is ttyGS0, this is the port corresponding to the Virtual COM. Now, to test it, you can send commands through the Arduino IDE, via the Serial console. In your Edison terminal enter the following:
cd /dev/
cat ttyGS0
Now, you can start writing on the Arduino Serial Monitor and you should see what you write in the Linux terminal.
If you want to write to the Linux terminal and receive the text to the Arduino Serial Monitor, enter the following:
echo "yourtext" > ttyGS0
PabloM_Intel
Pablo_M_Intel
Hi Christoph.P,
cd /dev/
cat ttyGS0
PabloM_Intel
CChri35
New Contributor II
Ok! Thank's! But one more Problem! If I type echo "yourtext" > ttyGS0 into my Linux Console, the Text always appears in the
Arduino IDE Console. But when I do a cat ttyGS0, the entered text not alway appears in the Linux console. It seems that the
the direction [arduino IDE] > [Linux Console @ Edison] is refused somehow.
Pablo_M_Intel
Hi Christoph.P,
That's weird, I'm not getting that behavior. I can see everything I enter in the Arduino Serial console after doing cat ttyGS0. Is your Edison running an Arduino sketch at the moment? It's possible that something is interfering with the port communication.
PabloM_Intel
CChri35
New Contributor II
No. I'm not running a sketch. Perhaps it has something to do with the fact, that some programs (Eclipse, Aurduino IDE) don't start when the Edison is connected over
USB and the Ethernet connection is active. It's a little bit weird.. It seems that the ethernet connection of the Edison blocks some low-level Windows acitvities. E.g.
the Windows Task manager does not show anything, when the Edison is conected and I open the Task manager. When I disconnect the Edison it seems that all tasks
are continued (the task manager is populated, eclipse starts instantly and so on).
And the Arduino IDE often says that there is nothing connected to COM1 although the windows device manager tells me the the edison is connected on COM1.
CChri35
New Contributor II
Seem that the serial connection is refused somehow. I will open a new thread for it,
because it seems to be an separated problem..
