Community
cancel
Showing results for
Search instead for
Did you mean:
Highlighted
Flash Intel IoT Edison with custom image
Jump to solution
I am working on intel edison board. I am trying to connect 3G dongle (huawei) to the board and make it work. For that I need usb-modeswitch package which I can get by adding this as
IMAGE_INSTALL_append += " usb-modeswitch"
in edison-image.bb . I followed the guide lines as per edisonbsp_ug and compiled the image successfully.
But I was not able to flash it on to the board. For flashing i have followed the guidelines
http://www.intel.com/support/edison/sb/CS-035280.htm# 4 Intel® Edison Boards — Flashing Intel® Edison (wired) - Linux*
I have tried both "reboot ota" and ./flashall.sh
I have attached the boot log here.
I am expecting the existing file system to be completely removed and that 3rd party packages that I have installed to come up when booting is done. But I always see the same old file system and the old u-boot & kernel gets loaded on boot time. Because the time stamps say that they have compiled last year but not the ones I have compiled (like: microkernel built 23:15:13 Apr 24 2014 and for u-boot: U-Boot 2014.04 (Aug 20 2014 - 16:08:32))
Please guide me how do I flash the edison board with the new images I have compiled
Accepted Solutions
Highlighted
I found the issue. I need to give
sudo ./flashall.sh
Now I can see my updated image file getting loaded
Highlighted
sudo ./flashall.sh
