Intel® Makers
9882 Discussions
Flash edison in Ubuntu
YYS_S
Hi there,
After struggling through yocto-image building process, I thought the hardest part has been passed... I was too naive... I should always keep "this is edison, failure is always an option" in mind.
My building computer is native ubuntu 16.04 LTS. Installed dfu-util already, the version is 0.8.
Then, running the flashing script generates the following error message of this:
sudo ./flashall.sh
Password:
Using U-boot target: edison-blank
Now waiting for dfu device 8087:0a99
Please plug and reboot the board
Device has DFU interface, but has no DFU functional descriptor
Cannot open DFU device 8087:0a99
On Edison side, it paused a bit then going to kernel boot as normal. I sincerely hope this is last bump on the road before having a fresh bitbaked image working on Edison. (I am still naive enough to hope this..... -_-!! )
Any suggestions are highly welcome. Thanks.
YYS_S
Hi Yermi,
Thanks for replying.
Comments to your suggestions: I tried with pre-compiled edison image, same error. Tried a few $5 to $1 usb cables, same error. Tried different ubuntu running laptop, same error. Tried powered usb hub, same error. External power source, same error.
Then, on windows platform, flashing works fine, no problem with any above mentioned usb cables, no problem with any usb ports, no problem with pre-compiled image, and customized image.
In short, found a work around. Thanks.
best,
Community Manager
Hi Anteater,
Thanks for your interest in the Intel® Edison Platform.
We're happy to know that you were able to build your Yocto image. First, we would like to know if you are able to flash your Edison by downloading the pre-built Yocto complete image (Here you can find steps to download the image and flash it: https://software.intel.com/en-us/flashing-firmware-on-your-intel-edison-board-linux Flashing the firmware on a system with Linux*), this is in order to discard issues with your build image.
Additionally, take a look at the following thread: /thread/60643 https://communities.intel.com/thread/60643, there you can find several suggestions like try with different USB cables and reinstall Edison drivers.
Hope this information helps.
-Yermi
YYS_S
Hi Yermi,
best,
Community Manager
Hi Anteater,
Thanks for sharing your workaround, we're happy to know that works fine.
-Yermi
