Community
cancel
Showing results for
Search instead for
Did you mean:
EFedo2
Flash multiple edisons from one PC simultaneously
Hello!
The title pretty much says it all - is there a way to flash multiple edisons connected to one PC in parallel using Flash tool lite or cli flashall script?
Thanks!
Matthias_H_Intel
I'm not aware. I used a setup with multiple hosts to flash lots of Edisons with flashall cli. With that you can get quite a throughput.
jhane2
the VID:PID of the edisons are the same so the flashall.sh script as it exist has no way of uniquely identify each edison. I see there is a -p option to dfu-util, perhaps if you know which port each edison is on you could modify the script to run on a specific port instead of just a "generic" edison device
good luck,
jeff
