Intel® Makers
9880 Discussions
Flash problem (dfu error)
Community Manager
Hello. I tried to flash yocto to Edison but I get an error. Here is the listing:
sudo ./flashall.sh
Using U-Boot target: edison-blankcdc
Now waiting for dfu device 8087:0a99
Please plug and reboot the board
Flashing IFWI
# ] finished!
# ] finished!
Flashing U-Boot
# ] finished!
Flashing U-Boot Environment
# ] finished!
Flashing U-Boot Environment Backup
# ] finished!
Rebooting to apply partition changes
Flashing boot partition (kernel)
# ] finished!
Flashing rootfs, (it can take up to 5 minutes... Please be patient)
# dfu_download: libusb_control_transfer returned -1
Rebooting
U-boot & Kernel System Flash Success...
Your board needs to reboot to complete the flashing procedure, please do not unplug it for 2 minutes.
Help me please.
Community Manager
It's very weird, but after using the phoneFlashTollLite with the error I tried flashall.sh again but with screen control. And it flashed my Edison. Thank you, Sergio.
Community Manager
First, make sure you're powering the board with an external power supply before attempting to flash. What OS are you using on your computer? Have you installed dfu-util before running the flashall such as in https://software.intel.com/en-us/flashing-firmware-on-your-intel-edison-board-linux https://software.intel.com/en-us/flashing-firmware-on-your-intel-edison-board-linux. What image are you attempting to flash?
Sergio
Community Manager
Thank you for response.
I tried with an external power and w/o it. I got the same result.
I use Ubuntu 14.04 on PC. I installed dfu-util. I tried to flash the latest image with yocto. But before this I had ubilinux with ROS,
Also I tried phoneFlashTollLite but unfortunately I have the follow error:
04/14/16 23:46:14.863 INFO : [Port 6] Running `"/usr/lib/phoneflashtoollite/dfu-util" "--alt" "u-boot-env1" "-D" "/home/duferob/Downloads/iot-devkit-prof-dev-image-edison-20160315/u-boot-envs/edison-blankcdc.bin" "-t" "4096" "-R" "-d" "8087:0a99"` command
04/14/16 23:46:15.930 WARNING: [Port 6] Command `"/usr/lib/phoneflashtoollite/dfu-util" "--alt" "u-boot-env1" "-D" "/home/duferob/Downloads/iot-devkit-prof-dev-image-edison-20160315/u-boot-envs/edison-blankcdc.bin" "-t" "4096" "-R" "-d" "8087:0a99"` failed
04/14/16 23:46:15.931 INFO : [Port 6] Retrying `"/usr/lib/phoneflashtoollite/dfu-util" "--alt" "u-boot-env1" "-D" "/home/duferob/Downloads/iot-devkit-prof-dev-image-edison-20160315/u-boot-envs/edison-blankcdc.bin" "-t" "4096" "-R" "-d" "8087:0a99"` command
04/14/16 23:46:16.056 ERROR : [Port 6] Command `"/usr/lib/phoneflashtoollite/dfu-util" "--alt" "u-boot-env1" "-D" "/home/duferob/Downloads/iot-devkit-prof-dev-image-edison-20160315/u-boot-envs/edison-blankcdc.bin" "-t" "4096" "-R" "-d" "8087:0a99"` failed
04/14/16 23:46:16.056 ERROR : [Port 6] Flash failed (Command type: DFU)
Community Manager
