Community
cancel
Showing results for
Search instead for
Did you mean:
ERedk
Flashing Custom board with IntelCurie (C1000) via Jtag (olimex-arm-usb-ocd-h)
Helllo! When I'try to flash I obtained next error log:
Open On-Chip Debugger 0.8.0-dev-g377d3f24-dirty (2017-04-11-19:24)
Licensed under GNU GPL v2
For bug reports, read
http://openocd.sourceforge.net/doc/doxygen/bugs.html
Info : only one transport option; autoselect 'jtag'
adapter speed: 1000 kHz
trst_only separate trst_push_pull
jtag_ntrst_delay: 300
Info : clock speed 1000 kHz
Info : JTAG tap: quark_se.cltap tap/device found: 0x0e765013 (mfg: 0x009, part: 0xe765, ver: 0x0)
Enabling arc core tap
Info : JTAG tap: quark_se.arc-em enabled
Enabling quark core tap
Info : JTAG tap: quark_se.quark enabled
Processor type: arc-em
Warn : target is still running !!
Error: tapstatus invalid - scan_chain serialization or locked JTAG access issues
redirect to PM, tapstatus=0xffffffff
Error: submit_pir TS_PIR_BIT did not clear, TS = 0xffffffff
Error: submit_instruction_pir error submitting pir
Polling target quark_se.quark failed, GDB will be halted. Polling again in 100ms
Polling target quark_se.quark failed, GDB will be halted. Polling again in 300ms
adapter speed: 1 kHz
Polling target quark_se.quark failed, GDB will be halted. Polling again in 700ms
Error: target running, halt it first
Runtime Error: C:/IntelSWTools/ISSM_2016.2.094/tools/debugger/openocd//scripts/target/quark_se.cfg:110:
in procedure 'clk32M'
in procedure 'mww' called at file "C:/IntelSWTools/ISSM_2016.2.094/tools/debugger/openocd//scripts/target/quark_se.cfg", line 110
In attachement my 'openocd' folder from '~\IntelSWTools\ISSM_2016.2.094\tools\debugger\'
And it's my preferences in ISSM:
Community Manager
Hi eugene.redkin,
As you are trying to flash the internal Quark SE C1000 available in the Curie module, I recommend you to post your issue in the Quark MCU community: https://communities.intel.com/community/tech/microcontrollers/content https://communities.intel.com/community/tech/microcontrollers/content
I'm not sure if what you are trying to accomplish is possible because you are not using a Quark SE C1000 board, you are using a Curie custom board which is not the same. The ISSM supports the Arduino 101 which is a Curie based board, but I'm not sure if it supports custom boards as well.
Anyhow, the best recommendation I can give you is to post this issue in the Quark MCU community for better assistance.
Diego V.
