can someone help me? I'm having a problem flashing my phone this is the error log
01/06/16 16:43:04.284 INFO : Intel(R) Phone Flash Tool Lite V 5.2.4.0 x86 (build on Monday April 27th 2015, 16:29:59 UTC)
01/06/16 16:43:04.284 INFO : Using xFSTK Downloader version: 1.8.0
01/06/16 16:43:04.964 INFO : Using DFU Downloader version: 0.8-msvc
01/06/16 16:43:05.741 INFO : Using Android Debug Bridge version 1.0.32
01/06/16 16:43:05.741 INFO : OS version detected: Windows 8.1 (x64)
01/06/16 16:43:05.741 INFO : SSL supported: No
01/06/16 16:43:05.866 INFO : Disk space available on drive C:/ : 5.47 GB
01/06/16 16:43:05.897 INFO : Ready to flash!
01/06/16 16:43:05.897 INFO : Flash file C:\Users\yhernz\Desktop\asus downloads\flash.xml [Default] loaded
01/06/16 16:43:06.690 INFO : Adb and fastboot binaries OK
01/06/16 16:43:07.024 INFO : Phone Flash Tool Lite initialized successfully
01/06/16 16:43:19.499 WARNING: Flash file C:/Users/yhernz/Desktop/asus downloads/flash.xml has changed on disk since it was loaded
01/06/16 16:43:23.246 INFO : Ready to flash!
01/06/16 16:43:23.250 INFO : Flash file C:\Users\yhernz\Desktop\asus downloads\flash.xml [Default] loaded
01/06/16 16:43:31.372 INFO : [Port 0/3] Start flashing the flash configuration with dnx_fw start state for 18CDA984EA46206B
01/06/16 16:43:31.372 INFO : [Port 0/3] Starting flash ...
01/06/16 16:43:31.372 INFO : [Port 0/3] Running `"xfstkFlashTool.exe" "C:\Zenfone\FwDnx.bin" "C:\Zenfone\ifwi.bin" "C:\Zenfone\OsDnx.bin" "C:\Zenfone\droidboot.img" "0x80000045" "none" "none"` command
01/06/16 16:43:32.143 INFO : [Port 0/3] Disabling xFSTK Misc DnX
01/06/16 16:43:32.143 INFO : [Port 0/3] Disabling xFSTK wipe out ifwi option
01/06/16 16:43:32.143 INFO : [Port 0/3] Using xFSTK Solo interface (new API)
01/06/16 16:43:32.143 INFO : [Port 0/3] xFSTK Soft Fuse not set
01/06/16 16:43:32.143 INFO : [Port 0/3] XFSTK Downloader API 1.8.0
01/06/16 16:43:32.143 INFO : [Port 0/3] Copyright (c) 2015 Intel Corporation
01/06/16 16:43:32.143 INFO : [Port 0/3] fwdnx -- C:\Zenfone\FwDnx.bin
01/06/16 16:43:32.143 INFO : [Port 0/3] fwimage -- C:\Zenfone\ifwi.bin
01/06/16 16:43:32.143 INFO : [Port 0/3] osdnx -- C:\Zenfone\OsDnx.bin
01/06/16 16:43:32.144 INFO : [Port 0/3] osimage -- C:\Zenfone\droidboot.img
01/06/16 16:43:32.144 INFO : [Port 0/3] gpflags -- 0x80000045
01/06/16 16:43:32.144 INFO : [Port 0/3] softfuse --
01/06/16 16:43:32.144 INFO : [Port 0/3] Qt: Untested Windows version 6.3 detected!
01/06/16 16:43:32.216 INFO : [Port 0/3] XFSTK-STATUS--Detecting Intel Device - Attempt # 0
01/06/16 16:43:33.384 INFO : [Port 0/3] ....XFSTK-LOG--USBSN:--virtual bool CloverviewPlusDownloader::SetDevice(IGenericDevice*)
01/06/16 16:43:33.384 INFO : [Port 0/3] Initiating download...
01/06/16 16:43:33.384 INFO : [Port 0/3] 98252
01/06/16 16:43:33.399 INFO : [Port 0/3] XFSTK-STATUS--USBSN:18CDA984EA46206B--FW download is in progress ...
01/06/16 16:43:33.399 INFO : [Port 0/3] XFSTK-STATUS--USBSN:18CDA984EA46206B--Softfuses Binary absent. Please provide binary.
01/06/16 16:43:33.399 INFO : [Port 0/3] XFSTK-STATUS--USBSN:18CDA984EA46206B--FAIL
01/06/16 16:43:33.399 INFO : [Port 0/3] XFSTK-STATUS--USBSN:18CDA984EA46206B--Errors encounter during FW download. Aborting ...
01/06/16 16:43:33.399 INFO : [Port 0/3] XFSTK: Transfer Completed Successfully.
01/06/16 16:43:33.399 INFO : [Port 0/3] Success: Download of FW and OS Completed.
01/06/16 16:43:33.399 INFO : [Port 0/3] xfstkFlashTool exited with success
01/06/16 16:43:33.399 INFO : [Port 0/3] Command `"xfstkFlashTool.exe" "C:\Zenfone\FwDnx.bin" "C:\Zenfone\ifwi.bin" "C:\Zenfone\OsDnx.bin" "C:\Zenfone\droidboot.img" "0x80000045" "none" "none"` succeed
01/06/16 16:43:33.399 INFO : [Port 0/3] Flash success (duration=00:00:02.027)
TIA
Hello yohernz,
We support the use of the Flash Tool Lite only for the Edison module. The use of the Flash Tool Lite for other devices is not supported in this community. I recommend you to post your question in the following sites; you might get a suggestion for your issue there:
- https://software.intel.com/en-us/forum https://software.intel.com/en-us/forum
- https://01.org/community Community | 01.org
Diego.
Hello yohernz,
Diego.
