Community
cancel
Showing results for
Search instead for
Did you mean:
Community Manager
Fresh Quark Board Bring-Up Issue
Hello everyone;
We have developed our custom board Based on Intel Quark x1000 Processor which is almost similar to Galileo rev 2 board except the RAM SIZE is 512MB(256MB+256MB).
We have loaded the Debug enabled "Flash+PlatformData.bin" into LSPI Flash. Flash+PlatformData.bin file was generated using the UDK2014.SPI source code.
Board boot up Process will stuck at the DXE Process as per Below logs.
Please Help us to solve the Issue as soon as possible.
Debug Log:
Platform Data Item List in System Area:
Quark Data Id:Len = 0x0001:0x0002 Desc = PlatformID Ver=0000
Quark Data Id:Len = 0x0006:0x0027 Desc = MrcParams Ver=0001
Quark Data Id:Len = 0x0003:0x0006 Desc = 1st MAC Ver=0000
Quark Data Id:Len = 0x0004:0x0006 Desc = 2nd MAC Ver=0000
Early Platform Thermal Sensor Init
Ioh MAC [B:0, D:20, F:6] VER:1037 ADDR:20-00-00-00-00-00
Ioh MAC [B:0, D:20, F:7] VER:1037 ADDR:20-00-00-00-00-00
Install PPI: 7408D748-FC8C-4EE6-9288-C4BEC092A410
Notify: PPI Guid: 7408D748-FC8C-4EE6-9288-C4BEC092A410, Peim notify entry point: 80015981
Reinstall PPI: 6F8C2B35-FEF4-448D-8256-E11B19D61077
Install PPI: F34C2FA0-DE88-4270-8414-961222F4521C
Flash Map PEIM Loaded
MRC Entry
MRC McFuseStat 0x00000429 : fus_dun_ecc_dis
MRC dram_width 0 rank_enables 1 ddr_speed 0
MRC flags: SCRAMBLE_EN
MRC density=2 tCL=6 tRAS=37500 tWTR=10000 tRRD=10000 tFAW=40000
MRC Version 0112 Nov 28 2016 10:21:08
Meminit build Nov 28 2016 10:21:07
POST: 0x100
POST: 0x101
POST: 0x200
POST: 0x200
POST: 0x103
POST: 0x104
POST: 0x300
POST: 0x300
POST: 0x310
POST: 0x311
POST: 0x312
POST: 0x313
POST: 0x314
POST: 0x400
POST: 0x400
POST: 0x105
POST: 0x106
POST: 0x500
POST: 0x500
POST: 0x510
POST: 0x600
POST: 0x600
POST: 0x610
POST: 0x630
POST: 0x120
POST: 0x700
POST: 0x700
POST: 0x710
POST: 0x711
POST: 0x712
POST: 0x713
POST: 0x720
RDQS T/B eye rank0 lane0 : 8-52 13-48
VREF R/L eye lane0 : 0-63 0-63
RDQS T/B eye rank0 lane1 : 5-55 9-50
VREF R/L eye lane1 : 0-63 0-63
POST: 0x740
POST: 0x800
POST: 0x800
POST: 0x810
POST: 0x811
WDQ eye rank0 lane0 : 234-287
WDQ eye rank0 lane1 : 243-297
POST: 0x10B
POST: 0x10C
POST: 0x10D
POST: 0x10E
POST: 0x110
POST: 0x111
POST: 0x112
POST: 0x113
HteMemInit....done
Memory test result 0
POST: 0x114
ALGO[CH:RK] BL0 BL1 BL2 BL3
RCVN[00:00] 463 464
WDQS[00:00] 294 301
WDQx[00:00] 260 270
RDQS[00:00] 030 029
VREF[00:00] 031 031
WCMD[00:00] 222 222
WCTL[00:00] 222 222
WCLK[00:00] 158 158
POST: 0x1FF
InstallEfiMemory.
Index 0, Page: 32
Index 1, Page: 3328
Index 2, Page: 96
Index 3, Page: 96
Index 4, Page: 64
Found 0xA0000 bytes at 0x0.
Found 0x60000 bytes at 0xA0000.
Found 0x1FCF0000 bytes at 0x100000.
Found 0x200000 bytes at 0x1FE00000.
Found 0x10000 bytes at 0x1FDF0000.
RedirectMemoryServicesSetPool Base:Size 0x00100000:0x1BED0000
PeiInstallPeiMemory MemoryBegin 0x1BFD0000, MemoryLength 0x2FE0000
RmuMain Base Address : 0x1FDF0000
Found Microcode ADDR:SIZE 0x80000514:0x2000
SaveConfig.
CpuData.CpuAddressWidth : 32
IIO[0] busbase = 0 Limit=FF
IIO[0] IoBase = 2000 IoLimit=FFFF
IIO[0] IoApicBase = FEC00000 IoApicLimit=FEC00FFF
IIO[0] Mem32Base = 90000000 Mem32Limit=AFFFFFFF
IIO[0] RcbaAddress=FED1C000
MemoryInit Complete.
Early PCIe controller initialisation
Platform Erratas After MRC
Register PPI Notify: F894643D-C449-42D1-8EA8-85BDD8C65BDE
Platform Erratas After MRC0
Temp Stack : BaseAddress=0x8007C000 Length=0x4000
Temp Heap : BaseAddress=0x80078000 Length=0x1608
Total temporary memory: 32768 bytes.
temporary memory stack ever used: 16384 bytes.
temporary memory heap used: 5640 bytes.
Old Stack size 16384, New stack size 131072
Stack Hob: BaseAddress=0x1BFD0000 Length=0x20000
Heap Offset = 0x64088000 Stack Offset = 0x64090000
Loading PEIM at 0x0001EFA4150 EntryPoint=0x0001EFA4240
PeiCore.efiImage.c
Reinstall PPI: 8C8CE578-8A3D-4F1C-9935-896185C32DD3
Reinstall PPI: 5473C07A-3DCB-4DCA-BD6F-1E9689E7349A
Reinstall PPI: B9E0ABFE-5979-4914-977F-6DEE78C278A6
Install PPI: F894643D-C449-42D1-8EA8-85BDD8C65BDE
Notify: PPI Guid: F894643D-C449-42D1-8EA8-85BDD8C65BDE, Peim notify entry point: 8002707D
Platform PEIM Memory Callback
Install PPI: EF398D58-9DFD-4103-BF94-78C6F4FE712F
Install PPI: 1F4C6F90-B06B-48D8-A201-BAE5F1CD7D56
Install PPI: 49EDB1C1-BF21-4761-BB12-EB0031AABB39
Notify: PPI Guid: 49EDB1C1-BF21-4761-BB12-EB0031AABB39, Peim notify entry point: 8000594B
The 1th FV start address is 0x0001EE83400, size is 0x00120000, handle is 0x1EE83400
Found firmware volume Image File 1EE83448 in FV[1] 1EE83400
Notify: PPI Guid: 49EDB1C1-BF21-4761-BB12-EB0031AABB39, Peim notify entry point: 80027CDA
PeiSecurityVerifyFv - CurrentFvAddress=0x1EE83400
CpuAddressWidth: 32
Loading PEIM at 0x0001EE81150 EntryPoint=0x0001EE81240
SmmAccessPei.efiImage.c
Install PPI: 268F33A9-CCCD-48BE-8817-86053AC32ED6
SMM Base:Size 1FE00000:00200000
Loading PEIM at 0x0001EE80150 EntryPoint=0x0001EE80240
SmmControlPei.efi
Install PPI: 61C68702-4D7E-4F43-8DEF-A74305CE74C5
Loading PEIM at 0x0001EE7A150 EntryPoint=0x0001EE7A240
DxeIpl.efiImage.c
Install PPI: EE4E5898-3914-4259-9D6E-DC7BD79403CF
Install PPI: A31280AD-481E-41B6-95E8-127F4C984779
Install PPI: 0AE8CE5D-E448-4437-A8D7-EBF5F194F731
Install PPI: 1A36E4E7-FAB6-476A-8E75-695A0576FDD7
Loading PEIM at 0x0001EE78150 EntryPoint=0x0001EE78240
PiSmmCommunicationPei.efi
Loading PEIM at 0x0001EE72150 EntryPoint=0x0001EE72240
S3Resume2Pei.efi
Install PPI: 6D582DBC-DB85-4514-8FCC-5ADF6227B147
Customized Guided section Memory Size required is 0x24C010 and address is 0x1EC20000
Extract guided section Failed - Invalid Parameter
Customized Guided section Memory Size required is 0x24C010 and address is 0x1E9CE000
DXE IPL Entry
Community Manager
Hi Nikunj,
Thank you for contacting us. We'll help you solve this this issue. Could you provide more details about how you created the Flash+PlatformData.bin file from the UDK2014 SPI source code? If you could provide the steps you followed or a link with information or files you used to create this file it'd be of great help.
Did you follow the steps on the Quark X1000 BSP? According to Section 9 of the Quark datasheet you need to create the Flash+PlatformData.bin file running the script platform-data-patch.py, which can be found in the spi-flash-tools tarball. Did you run this script to create this file?
I also noticed the line which says Customized Guided section Memory Size required is 0x24C010 and address is 0x1EC20000. Did you do any software related customization that's related to this message?
I'll be waiting for your response.
-Sergio
Community Manager
We are following below configuration for Hardware & software.
  • Hardware : We have prototype based on Intel Galileo Gen2 board with Intel Quark X1000 chipset:
    • DDR3 upgrade to 512MB with Channel 0 , Rank 0 Low memory down configure.
    • No PCIe connections
    • No GPIO Mux or Expander
  • Software :
    • We have used following Quark EDKII to start actual grub loader after configuring and loading PEI modules, DXE core & modules and SMM modules using UEFI Shell.
      • Quark EDKII 1.1.0 (We are using)
      • Quark EDKII 1.2.1 (We have checked to verify issue and getting same issue)
    • We have verified following DDR3 memory related parameters into sample-plateform-data.ini file which is stored inside platform-data section and we have generated Flash+PlaformData.bin after applying patch of ini file.
data[00-01] - platform_id u16 - should match value of platform type/id record as sanity check.0800# data[02-05] - flags u32 - bit[0] ECC_EN, bit[1] SCRAMBLE_EN, others=RESERVED02000000# data[06] - dram_width u8 - 0=x8, 1=x16, others=RESERVED.00# data[07] - dram_speed u8 - 0=DDRFREQ_800, 1=DDRFREQ_1066, others=RESERVED. Only 533MHz SKU support 1066 memory.00# data[08] - dram_type u8 - 0=DDR3, 1=DDR3L, others=RESERVED.00# data[09] - rank_mask u8 - bit[0] RANK0_EN, bit[1] RANK1_EN, others=RESERVED.01# data[0A] - chan_mask u8 - bit[0] CHAN0_EN, others=RESERVED..01# data[0B] - chan_width u8 - 1=x16, others=RESERVED.01# data[0C] - addr_mode u8 - 0, 1, 2 (mode 2 forced if ecc enabled), others=RESERVED00# data[0D] - sr_int u8 - 1=1.95us, 2=3.9us, 3=7.8us, others=RESERVED. REFRESH_RATE.03# data[0E] - sr_temp u8 - 0=normal, 1=extended, others=RESERVED. SR_TEMP_RANGE.00# data[0F] - dram_ron_val u8 - 0=34ohm, 1=40ohm, others=RESERVED. RON_VALUE Select MRS1.DIC driver impedance control.00# data[10] - dram_rtt_nom_val u8 - 0=40ohm, 1=60ohm, 2=120ohm, others=RESERVED. RTT_NOM_VALUE.02# data[11] - dram_rtt_wr_val u8 - 0=off, others=RESERVED00# data[12] - soc_rd_odt_val u8 - 0=off, 1=60ohm, 2=120ohm, 3=180ohm, others=RESERVED. RD_ODT_VALUE.00# data[13] - soc_wr_ron_val u8 - 0=27ohm, 1=32ohm, 2=40ohm, others=RESERVED. (WR_RON_VALUE select Vref code for DQ DRV PU evaluation using external resistor).01# data[14] - soc_wr_slew u8 - 0=2.5V/ns, 1=4V/ns, others=RESERVED. (WR_SLEW_RATE).01# data[15] - dram_density u8 - 0=512Mb, 1=Gb, 2=2Gb, 3=4Gb, others=RESERVED.02# data[16-19] - tRAS u32 - ACT to PRE command period in picoseconds.7C920000# data[1A-1D] - tWTR u32 - Delay from start of internal write transaction to internal read command in picoseconds.10270000# data[1E-21] - tRRD u32 - ACT to ACT command period (JESD79 specific to page size 1K/2K) in picoseconds.10270000# data[22-25] - tFAW u32 - Four activate window (JESD79 specific to page size 1K/2K) in picoseconds.409c0000# data[26] - tCL u8 - DRAM CAS Latency in cl06
  • So, we have updated DRAM density to 02 as per DDR3 RAM size 512MB (256MB x 2) into ini file and it seems like initial block 32 MB of Total RAM is initialized after that settings. All other parameters are same as Intel Galileo Gen 2 board which we are using now for our development purpose.
  • We are also using following commands to generate Flash+PlaformData.bin in debug mode to get all debug logs on UART1 after flashing that bin file into LSPI Flash using Dediprog tool and starting debug console on UART1 with baud-rate 115200.
  • ./buildallconfigs.sh GCC46 QuarkPlatform ---> Build EDKII source files
  • ../../spi-flash-tools_v1.1.0/Makefile ---> To generate Flash-missingPDAT.bin which should be stored into SPI Flash
  • python platform-data-patch.py -p sample-platform-data.ini -i ../../sysimage_*/sysimage.CP-8M-debug/Flash-missingPDAT.bin ---> To apply platform data patch means ini file related changes which we have made as per above data
  • sudo ./flashrom -p dediprog -w Flash+PlatformData.bin ---> To flash final image into LSPI Flash
Issue : Board boot-up process is stuck while extracting GUID section decode in DxeLoad.c file which is mainly used to customize guided section memor...
Community Manager
Hi Nikunj,
Thank you for providing such a detailed response. I've a few comments and suggestions:
-You said you've updated the DRAM density value to 02. In the data[15] line which is underlined you should choose the 512Mb option, which can be seen here https://kernel.googlesource.com/pub/scm/linux/kernel/git/jejb/Quark_EDKII/+/master/galileo-platform-... https://kernel.googlesource.com/pub/scm/linux/kernel/git/jejb/Quark_EDKII/+/master/galileo-platform-... . Confirm you've chosen the appropriate value in this point.
-Next, where you typed this command ./buildallconfigs.sh GCC46 QuarkPlatform, you have to take into account this applies for release 1.1 and earlier and you said you also tried 1.2.1 so make sure you've used the correct command for the version you're trying. Also, depending on the release you're using you have to take into consideration the GCC version installed on your system. For GCC4x there's a note that says: "GCC flags used for this build. Set to the version of GCC you have installed. Note: Tested on GCC46. GCC43 is not supported from release 1.2 onwards." Which GCC version do you have installed on your system? You can see these notes in the Quark X1000 BSP section 4. http://www.intel.com/content/www/us/en/embedded/products/quark/quark-x1000-bsp-build-sw-rel-user-gui... http://www.intel.com/content/www/us/en/embedded/products/quark/quark-x1000-bsp-build-sw-rel-user-gui...
-Also, in the last section I noticed you set dram_speed = DDRFREQ_1066. Remember that 1066MHz DDR3 RAM is not supported, as can be seen in this thread /thread/108051 https://communities.intel.com/thread/108051 .
Let us know if you find this useful.
-Sergio
Community Manager
Hello Sergio;
Thanks for your help;
  • No GPIO Mux or Expander.
We have compile same code with above method and load into Galileo Rev 2 board . Galileo Rev 2 Board is proper boot up and proper work with the SD imge mode and Flash image Mode.
We have load same code in our custom board but it is not proper work and stop with below error. Also behaviour of our board is random means some time stop at "Platform PEIM Memory Callback" and some time stop with "Extract guided section Failed - Invalid Parameter" error.
If you have face any problem related to this please help us how to debug with hardware point of view or tell us if any our debugging method to debug our custom board.
Debug Log:
Install PPI: 1E2ACC41-E26A-483D-AFC7-A056C34E087B
Register PPI Notify: 3ACF33EE-D892-40F4-A2FC-3854D2E1323D
Loading PEIM at 0x00080012C6C EntryPoint=0x00080012D5C FaultTolerantWritePei.efi
Install PPI: 1D3E9CB8-43AF-490B-830A-3516AA532047
Loading PEIM at 0x00080013EA4 EntryPoint=0x00080013F94 PeiVariable.efi
Install PPI: 2AB86EF5-ECB5-4134-B556-3854CA1FE1B4
Loading PEIM at 0x00080015894 EntryPoint=0x00080015984 CpuPei.efi
Install PPI: C153205A-E898-4C24-8689-A4B4BCC5C8A2
Register PPI Notify: 7408D748-FC8C-4EE6-9288-C4BEC092A410
Loading PEIM at 0x00080018CCC EntryPoint=0x00080018DBC CapsulePei.efi
Install PPI: 3ACF33EE-D892-40F4-A2FC-3854D2E1323D
Notify: PPI Guid: 3ACF33EE-D892-40F4-A2FC-3854D2E1323D, Peim notify entry point: 800247C5
IsFirstBoot = 1 , EnableFastBoot= 1.
BootMode: FullCfg
Register PPI Notify: 49EDB1C1-BF21-4761-BB12-EB0031AABB39
Quark EDKII SECURE LOCKDOWN DISABLED
Quark EDKII Stage1 Boot Image 0
Quark EDKII Stage2 0xFFD70400:0x0011FC00 - Payload 0xFF800400:0x00100000
Ioh MAC [B:0, D:20, F:6] VER:1037 ADDR:02-00-00-00-00-00
Ioh MAC [B:0, D:20, F:7] VER:1037 ADDR:02-00-00-00-00-01
Notify: PPI Guid: 7408D748-FC8C-4EE6-9288-C4BEC092A410, Peim notify entry point: 80015B72
MRC Entry
MRC Version 0112 Nov 29 2016 11:24:19
Meminit build Nov 29 2016 11:24:18
POST: 0x100
POST: 0x101
POST: 0x200
POST: 0x200
POST: 0x103
POST: 0x104
POST: 0x300
POST: 0x300
POST: 0x310
POST: 0x311
POST: 0x312
POST: 0x313
POST: 0x314
POST: 0x400
POST: 0x400
POST: 0x105
POST: 0x106
POST: 0x500
POST: 0x500
POST: 0x510
POST: 0x600
POST: 0x600
POST: 0x610
POST: 0x630
POST: 0x120
POST: 0x700
POST: 0x700
POST: 0x710
POST: 0x711
POST: 0x712
POST: 0x713
POST: 0x720
RDQS T/B eye rank0 lane0 : 7-53 13-49
RDQS T/B eye rank0 lane1 : 5-54 9-50
POST: 0x740
POST: 0x800
POST: 0x800
POST: 0x810
POST: 0x811
WDQ eye rank0 lane0 : 235-287
POST: 0x10B
POST: 0x10C
POST: 0x10D
POST: 0x10E
POST: 0x110
POST: 0x111
POST: 0x112
POST: 0x113
HteMemInit....done
POST: 0x114
RCVN[00:00] 464 465
WDQS[00:00] 294 301
WDQx[00:00] 261 270
RDQS[00:00] 030 029
VREF[00:00] 031 031
WCMD[00:00] 222 222
WCTL[00:00] 222 222
WCLK[00:00] 158 158
POST: 0x1FF
InstallEfiMemory.
Index 0, Page: 32
Index 1, Page: 3328
Index 2, Page: 96
Index 3, Page: 96
Index 4, Page: 64
Found Microcode ADDR:SIZE 0x80000504:0x2000
SaveConfig.
Temp Heap : BaseAddress=0x80078000 Length=0x1620
temporary memory heap used: 5664 bytes.
Loading PEIM at 0x0001EFA4150 EntryPoint=0x0001EFA4240 PeiCore.efi
Notify: PPI Guid: F894643D-C449-42D1-8EA8-85BDD8C65BDE, Peim notify entry point: 800261E7
Notify: PPI Guid: 49EDB1C1-BF21-4761-BB12-EB0031AABB39, Peim notify entry point: 80005974
The 1th FV start address is 0x0001EE84400, size is 0x0011FC00, handle is 0x1EE84400
Found firmware volume Image File 1EE84448 in FV[1] 1EE84400
Notify: PPI Guid: 49EDB1C1-BF21-4761-BB12-EB0031AABB39, Peim notify entry point: 80026D18
PeiSecurityVerifyFv - CurrentFvAddress=0x1EE84400
CpuAddressWidth: 32
Loading PEIM at 0x000...
Community Manager
Hi Nikunj,
I want to double check to make sure I'm understanding your issue correctly. You said that the image you flashed onto the Galileo and your custom board is the same, and that that image boots only on the Galileo, is this correct? I also looked at the Platform PEIM Memory Callback message you highlighted and this doesn't seem to be an error. What seems to be causing this is the message before Extract guided section Failed - Invalid Parameter, that's related to memory.
In our previous reply we asked about the dram density, the GCC compiler used and the supported memory types. Have you checked that you're using the appropriate configurations, compilers and a supported memory configuration?
The debugging options available for the Quark X1000 can be found here https://www-ssl.intel.com/content/www/us/en/embedded/products/quark/x1000/documentation.html https://www-ssl.intel.com/content/www/us/en/embedded/products/quark/x1000/documentation.html in the documents OpenOCD Source Level Debug: Application Note and Debug Operations: Specification Update.
We'll be waiting for your response.
-Sergio
Community Manager
Hello Sergio;
Our Board Total dram Density: 512MB.
We are using GCC46 for compile the code.
We have been used same DDR3 RAM . just only change the double density (256MB instead of 128MB).
Thanks in advance.
Community Manager
Hi Nikunj,
There's some configuration that needs to be done in order to enable the DDR3. Have you modified any of these files? They can be found in section 5.7 of the UEFI Firmware Writers Guide.
You can find the guide here http://www.intel.com/content/www/us/en/embedded/products/quark/quark-x1000-uefi-firmware-writers-gui... . Section 5 has information about the DDR3 configuration. Let us know which files you edited and their contents.
-Sergio
Sergio_A_Intel
Hi Nikunj,
Do you still need assistance with this case? Did you find useful the information we posted?
-Sergio
SSiri2
We are observing the similar issue. May I know the fix/configuration made in Quark BIOS?
Community Manager
Hi jlkjk;
This was the issue related to the hardware and most likely ddr3 ram. I think you should resolder the ddr3 ram or processor.
