Hi DatDinh,
What do you have on each pin (pin 2 in the pictures you included in your post)?
Is there any reason for using INPUT_PULLUP instead of INPUT?
Fernando.
Hi FGT.
I also tried to test on pin 2 with mode INPUT but It also didn't work. However when I run mode OUTPUT, it worked. As well as with the other pins 0, 1, 3, 10, 11, 12, 13. I use pin 2 because I want to use external interrupt to share data between arduino IDE with node js on Intel Galielo. But the interrupt didn't work because data read from pin 2 is wrong when I push button and don't push , it forever is Zero .
I see...
Please post your wiring as well as the button model/hardware, with a picture, if possible.
Also, take into account that there are other methods to share information, e.g. pipes.
Fernando.
Hi FGT.
Thanks for your help. The truth my kit is IO error(pin 0, 1, 2, 3). I tried it with the other and the result is good.
Is your issue resolved? If you believe some IO pins are not working as they should you can fill this form here so we can take a closer look to your case https://customercare.intel.com/?lang=en-US https://customercare.intel.com/?lang=en-US
-Sergio
