Hi, I see many intel edison project with GitHub file. But how do faires are run on intel edison ??
Hi vianney,
Could you please share some more details about what you want to do so we can help you better? What do you mean by "faires"?
PabloM_Intel
hey, I'm sorry I do not speak good English, I am French. I made gréât looking and finally I find. I install:
echo src/gz all http://repo.opkg.net/edison/repo/all http://repo.opkg.net/edison/repo/all > /etc/opkg/base-feeds.conf
echo src/gz edison http://repo.opkg.net/edison/repo/allsrc/gz http://repo.opkg.net/edison/repo/allsrc/gz >> /etc/opkg/base-feeds.conf
echo src/gz core2-32 http://repo.opkg.net/edison/repo/allsrc/gz http://repo.opkg.net/edison/repo/allsrc/gz >> /etc/opkg/base-feeds.conf
echo src all http://iotdk.intel.com/repos/1.1/iotdk/all http://iotdk.intel.com/repos/1.1/iotdk/all >> /etc/opkg/base-feeds.conf
echo src x86 http://iotdk.intel.com/repos/1.1/iotdk/x86 http://iotdk.intel.com/repos/1.1/iotdk/x86 >> /etc/opkg/base-feeds.conf
echo src i586 http://iotdk.intel.com/repos/1.1/iotdk/i586 http://iotdk.intel.com/repos/1.1/iotdk/i586 >> /etc/opkg/base-feeds.conf
and now I can make git clone without it corrupting my image
echo src/gz all http://repo.opkg.net/edison/repo/all http://repo.opkg.net/edison/repo/all > /etc/opk g/base-feeds.conf
root@vianney:~# echo src/gz edison http://repo.opkg.net/edison/repo/allsrc/gz http://repo.opkg.net/edison/repo/allsrc/gz > > /etc/opkg/base-feeds.conf
root@vianney:~# echo src/gz core2-32 http://repo.opkg.net/edison/repo/allsrc/gz http://repo.opkg.net/edison/repo/allsrc/gz >> /etc/opkg/base-feeds.conf
root@vianney:~# opkg update
Downloading http://repo.opkg.net/edison/repo/all/Packages.gz http://repo.opkg.net/edison/repo/all/Packages.gz.
Inflating http://repo.opkg.net/edison/repo/all/Packages.gz http://repo.opkg.net/edison/repo/all/Packages.gz.
Updated list of available packages in /var/lib/opkg/all.
Downloading http://repo.opkg.net/edison/repo/allsrc/gz/Packages.gz http://repo.opkg.net/edison/repo/allsrc/gz/Packages.gz.
Downloading http://iotdk.intel.com/repos/1.1/intelgalactic/Packages http://iotdk.intel.com/repos/1.1/intelgalactic/Packages.
Updated list of available packages in /var/lib/opkg/maa-upm.
Downloading http://iotdk.intel.com/repos/1.5/intelgalactic/Packages http://iotdk.intel.com/repos/1.5/intelgalactic/Packages.
Updated list of available packages in /var/lib/opkg/iotkit.
Updated list of available packages in /var/lib/opkg/mraa-upm.
Collected errors:
* opkg_download: Failed to download http://repo.opkg.net/edison/repo/allsrc/gz/ http://repo.opkg.net/edison/repo/allsrc/gz/ Packages.gz, wget returned 8.
root@vianney:~# opkg install bluez5-dev
Package bluez5-dev (5.24-r0) installed in root is up to date.
root@vianney:~# npm install -g async
async@1.4.2 /usr/lib/node_modules/async
root@vianney:~# npm install noble
npm WARN package.json mraa@0.8.0 No repository field.
npm WARN optional dep failed, continuing xpc-connection@0.1.4
> usb@1.0.6 install /home/root/node_modules/noble/node_modules/bluetooth-hci-soc ket/node_modules/usb
> node-pre-gyp install --fallback-to-build
make: Entering directory '/home/root/node_modules/noble/node_modules/bluetooth-h ci-socket/node_modules/usb/build'
CC(target) Release/obj.target/libusb/libusb/libusb/core.o
CC(target) Release/obj.target/libusb/libusb/libusb/descriptor.o
CC(target) Release/obj.target/libusb/libusb/libusb/hotplug.o
CC(target) Release/obj.target/libusb/libusb/libusb/io.o
CC(target) Release/obj.target/libusb/libusb/libusb/strerror.o
CC(target) Release/obj.target/libusb/libusb/libusb/sync.o
CC(target) Release/obj.target/libusb/libusb/libusb/os/poll_posix.o
CC(target) Release/obj.target/libusb/libusb/libusb/os/threads_posix.o
../libusb/libusb/os/threads_posix.c:24:0: warning: "_GNU_SOURCE" redefined
# define _GNU_SOURCE
:0:0: note: this is the location of the previous definition
CC(target) Release/obj.target/libusb/libusb/libusb/os/linux_usbfs.o
CC(target) Release/obj.target/libusb/libusb/libusb/os/linux_udev.o
../libusb/libusb/os/linux_udev.c:40:21: fatal error: libudev.h: No such file or directory
# include
compilation terminated.
libusb.target.mk:121: recipe for target 'Release/obj.target/libusb/libusb/libusb /os/linux_udev.o' failed
make: *** [Release/obj.target/libusb/libusb/libusb/os/linux_udev.o] Error 1
make: Leaving directory '/home/root/node_modules/noble/node_modules/bluetooth-hc i-socket/node_modules/usb/build'
gyp ERR! build error
gyp ERR! stack Error: `make` failed with exit code: 2
gyp ERR! stack at ChildProcess.onExit (/usr/lib/node_modules/npm/node_module ...
Hi vianney,
It should be this way:
echo src/gz all http://repo.opkg.net/edison/repo/all/ http://repo.opkg.net/edison/repo/all/ > /etc/opkg/base-feeds.conf
echo src/gz core2-32 http://repo.opkg.net/edison/repo/core2-32/ http://repo.opkg.net/edison/repo/core2-32/ >> /etc/opkg/base-feeds.conf
echo src/gz edison http://repo.opkg.net/edison/repo/edison/ http://repo.opkg.net/edison/repo/edison/ >> /etc/opkg/base-feeds.conf
Remember that just one greater than sign (>) will overwrite any text that is in the file, and two greater than signs (>>) will append or add the new data to the existing text, it won't delete the text that is already in the file.
Also, make sure that the file names from the AlexT repo and the IoT repository don't share the same names as it would probably give errors when downloading.
PabloM_Intel
