Intel® Makers
9881 Discussions
GPIO C code convert to C++
jnich3
I am attempting to convert some C code from http://www.i-programmer.info/programming/hardware/8744-exploring-edison-mraa-gpio.html?start=2 here to C++
My code:
# include "mraa.hpp"
# include
# include
# include
using namespace std;
void switchChange(void* args);
int main(){
mraa::Gpio* gpio36 = new mraa::Gpio(36);
gpio36->dir(mraa::DIR_IN);
gpio36->isr(mraa::EDGE_FALLING, &switchChange, gpio36);
for (;;) {};
return MRAA_SUCCESS;
void switchChange(void* args){
int s = args->read ;
cout << "switch" << s << endl;</span>
error message is:
make temp2
i586-poky-linux-g++ -m32 -march=core2 -mtune=core2 -msse3 -mfpmath=sse -mstackrealign -fno-omit-frame-pointer --sysroot=/opt/poky-edison/1.7.2/sysroots/core2-32-poky-linux -lmraa -o temp2 temp.cpp
temp.cpp: In function 'void switchChange(void*)':
temp.cpp:17:14: error: 'void*' is not a pointer-to-object type
make: *** [temp2] Error 1
I.e. I am not sure how to get the read info from args in the interrupt handler?
I realise this is a bit of a coding newby question, but I have a number of others that follow on from this, once this is cracked
Andriy_S_Intel
In C (C++ follows that as well) you have to declare structure before usage.
For example:
struct mystruct {
int read;
void myfunc(void *args) {
struct mystruct *ms = args;
printf("Args->read: %d\n", args->read);
Otherwise compiler doesn't know what to do with undefined variables.
jnich3
I'm not sure I totally follow this. Isn't gpio36 a pointer to a Gpio object, in which case shouldn't the struct definition reflect the structure of a Gpio?
Code wise are you suggesting the following? Becuase this still produces error as shown below
# include
# include
# include
struct mystruct {
int read;
int main(){
for (;;) {};
int s = args->read;
because this gives error:
make temp2
temp.cpp:22:23: error: invalid conversion from 'void*' to 'mystruct*' [-fpermissive]
temp.cpp:23:13: error: 'void*' is not a pointer-to-object type
int s = args->read;
jnich3
Because we are passing a void pointer to the interrupt function we need to convert this to some more meaningful form within the function.
So, in this case we are passing a pointer to a gpio pin. So we need to cast the void pointer to a gpio pointer. Then we can access it. See commented code.
# include
# include
# include
int main() {
for (;;) {};
void switchChange(void* args) {
// args is a void pointer and needs to be cast to a pointer to a gpio
mraa::Gpio* myArgs = (mraa::Gpio*) args;
// then we can get value
int s = myArgs->read();
