Community
cancel
Showing results for
Search instead for
Did you mean:
IBanc
GPIO as TX RX
Jump to solution
I already know that we have UARTs on Intel Edison, but I would like to ask if it is possible to turn almost any GPIO into Tx Rx pins, let's say GP14 to be TX and GP15 to be RX. Another way to say, it is that i would like to have more tx rx ports for multiple sensors that use serial communication - like 2 GSM modules and one 2 GPS receivers or even more.
Thank You!
Community Manager
Bitbanging would be a solution but I think this is not possible using the edison to achive accurate timings, maybe
by programming the MCU.
Another solution is using a multiplexer like 4052 (http://www.nxp.com/documents/data_sheet/74HC_HCT4052.pdf http://www.nxp.com/documents/data_sheet/74HC_HCT4052.pdf).
With this solution you can use differnent moduls, but you must care about the current one...buffers may overflow
while handling another module...
So I think the best solution is to get more serial interfaces by using an FTDI.
There are different ones up to 4 serial channels. You only must include the driver to the kernel.
All channels can be used "parallel", all the buffering stuff is done by the FTDI.
Flo1991
Community Manager
Flo1991
Community Manager
Hi losif,
The suggestion gave by Flo1991 it is a good idea.
You have to consider the speed required for the sensors you will have connected to the board. The GPIOs work at 100ns for a 50MHz clock
Take a look at: http://www.intel.com/content/dam/support/us/en/documents/edison/sb/edisonmodule_hg_331189004.pdf http://www.intel.com/content/dam/support/us/en/documents/edison/sb/edisonmodule_hg_331189004.pdf
Currently the libraries available consider the UART available on pins 0 and 1. You would need to create your custom library that emulates the functionality of an UART for other pins.
Charlie
IBanc
Flo1991 & intel_corp
Thank You!
