Intel® Makers
GPT vs MBR
jhane2
I've seen an issue with the partitions on the Edison when changing the sizes and was just poking around a little bit. I notice that when flashing the device, u-boot prints out that is creating a the partition table using GPT. Out of curiosity I installed the gptfdisk and here is what I see
root@dirty:~# gdisk /dev/mmcblk0
GPT fdisk (gdisk) version 1.0.0
Caution: invalid backup GPT header, but valid main header; regenerating
backup header from main header.
Warning! One or more CRCs don't match. You should repair the disk!
Partition table scan:
MBR: protective
BSD: not present
APM: not present
GPT: damaged
Caution: Found protective or hybrid MBR and corrupt GPT. Using GPT, but disk
verification and recovery are STRONGLY recommended.
root@dirty:~# gdisk /dev/mmcblk0p9
MBR: MBR only
BSD: not present
APM: not present
GPT: not present
Found invalid GPT and valid MBR; converting MBR to GPT format
in memory. THIS OPERATION IS POTENTIALLY DESTRUCTIVE! Exit by
typing 'q' if you don't want to convert your MBR partitions
to GPT format!
Maybe I just don't understand what is going on here yet; however, I expected that if the partition table was GPT that the gdisk would work. Instead, the tools seem to indicate that it is not GPT, or at least not valid.
Anyone have any insight into what is going on here?
thanks,
jeff
Carlos_M_Intel
Hi Jeff,
I'm sorry for the delay in our response. The GTP: damaged message seems to be related with the Edison using MMC as storage device and not a hard drive. Even though, you can ignore these messages as they are just warnings.
Charlie
Carlos_M_Intel
Hi jeff,
I will investigate more about this but I would like to know if this is happening always, no matter the size of the partition.
Also, have you tried to use gptfdisk with the standard image not the custom one?
Charlie
jhane2
results from a fresh from the box edison and then after flashing with ww18-15. But now there is that disturbing overlap message that I didn't see before.
jeff
marvel [2254] % cat foo
root@edison:~# cat /etc/version
edison-weekly_build_56_2014-08-20_15-54-05
root@bugger:~# gdisk /dev/mmcblk0
MBR: protective
BSD: not present
APM: not present
GPT: damaged
Command (? for help): q
root@bugger:~# gdisk /dev/mmcblk0p9
MBR: MBR only
BSD: not present
APM: not present
GPT: not present
to GPT format!
Warning! Main partition table overlaps the first partition by 18 blocks!
Try reducing the partition table size by 72 entries.
(Use the 's' item on the experts' menu.)
Warning! Secondary partition table overlaps the last partition by
33 blocks!
You will need to delete this partition or resize it in another utility.
# 3
root@bugger:~# cat /etc/version
weekly-146
root@bugger:~#
MBR: protective
BSD: not present
APM: not present
GPT: damaged
MBR: MBR only
BSD: not present
APM: not present
GPT: not present
to GPT format!
33 blocks!
Carlos_M_Intel
Hi jeff,
I'm still investigating about this. After using parted > print all are you still having "Partition Table: gpt for the /dev/mmcblk0" in the log? The mmcblk0 could have been set as GPT and the other ones can be set differently so that could be the reason of the MBR only/protected GPT damaged in your log
Charlie
jhane2
Running parted > print all didn't change anything but I wouldn't expect it to. Thanks for looking into this. Obviously the system is working, I'm just trying to understand if there is some kind of issue or not.
thanks,
jeff
Carlos_M_Intel
Hi Jeff,
We would like to replicate your environment and do some tests. Did you build gptfdisk source, downloaded the package or did you installed it from a repo?
jhane2
I grabbed a recipe from somewhere and built it in my yocto environment. I can't access my other system right now so can't tell you exactly what the recipe is.
jeff
Carlos_M_Intel
Hi jeff,
Do you remember if you used the openembedded-core layer from http://layers.openembedded.org/layerindex/branch/dizzy/layers/ OpenEmbedded Metadata Index - layers and this recipe http://recipes.yoctoproject.org/rrs/recipedetail/185/ Recipe reporting system - gptfdisk
If this was not the recipe you used, could you provide us .bb file?
Charlie
jhane2
Not sure at this point so here is the recipe:
DESCRIPTION = "GPT fdisk is a disk partitioning tool loosely modeled on Linux fdisk, but used for modifying GUID Partition Table (GPT) disks. The related FixParts utility fixes some common problems on Master Boot Record (MBR) disks."
LICENSE = "GPLv2"
LIC_FILES_CHKSUM = "file://COPYING;md5=59530bdf33659b29e73d4adb9f9f6552"
DEPENDS = "util-linux popt ncurses"
SRC_URI = "${SOURCEFORGE_MIRROR}/${BPN}/${PV}/${BP}.tar.gz"
SRC_URI[md5sum] = "2061f917af084215898d4fea04d8388f"
SRC_URI[sha256sum] = "5b66956743a799fc0471cdb032665c1391e82f9c5b3f1d7d726d29fe2ba01d6c"
do_install() {
install -d ${D}${sbindir}
install -m 0755 cgdisk ${D}${sbindir}
install -m 0755 gdisk ${D}${sbindir}
install -m 0755 sgdisk ${D}${sbindir}
install -m 0755 fixparts ${D}${sbindir}
BBCLASSEXTEND = "native nativesdk"
Carlos_M_Intel
Hi jeff,
Thank you, we are still investigating in order to identify why you are getting those messages while using gdisk.
Charlie
Carlos_M_Intel
Hi Jeff,
Charlie
