I want to try GSM GPRS GPS Module A7 breakout on Intel edison arduino expansion board.I have tried connecting the UART1 to intel edison using RS232.I'm able to configure UART1 .I want to kow whether there is feasability of GSM GPRS GPS module ??? Can you please let me know the details of the pin configuration ..??
Please do needful.
Thanks and Regards,
Radhika
Hi Radhika,
Thank you for contacting us.
I didn't find any information related about this module, can you give the pin configuration of the module?
I just found this shield that maybe can be helpful for you: http://www.elecrow.com/wiki/index.php?title=A7_GPRS%2BGSM%2BGPS_Shield, this is an Arduino shield and there is a pin configuration that you can use as reference for the connections that you want.
I hope you find this useful.
-Leonardo
Hi Leonardog ,
I am also looking same information.
Here is the pin out A6 and A7 GSM+GPRS module.
A6 or A7 Working voltage : 3.3V-4.2V; Power voltage: >3.4V
http://www.electrodragon.com/w/GSM_GPRS_A6_Module# A7_Pin_Definitions GSM GPRS A6 Module - ElectroDragon
http://smart-prototyping.com/image/data/9_Modules/101756%20Wireless%20A6C/A6_A7_A6C_datasheet-EN.pdf http://smart-prototyping.com/image/data/9_Modules/101756%20Wireless%20A6C/A6_A7_A6C_datasheet-EN.pdf
Sree
Hi Sree,
I didn't find any useful information, or workarounds about this. Personally, my recommendation is to look the Eagle files of the shield: http://www.elecrow.com/wiki/index.php?title=File:A7_GPRS_GSM_Shield.zip, you can check there the pin configuration of the module in the shield, and use it as reference and how to connect it to the Edison.
I hope you find this helpful.
-Leonardo
