Community
cancel
Showing results for
Search instead for
Did you mean:
Highlighted
Galileo Arduino compiler/linker error: Undefined Reference to Main
Hello, Getting the following compiler/linker error:
C:/arduino-1.5.3/hardware/tools/x86/i586-poky-linux-uclibc/usr/lib/../lib/crt1.o: In function `_start':
/dev/shm/kmsywula/tmp/work/i586-poky-linux-uclibc/uclibc/0.9.33+gitAUTOINC+946799cd0ce0c6c803c9cb173a84f4d607bde350-r8.4/git/libc/sysdeps/linux/i386/crt1.S:123: undefined reference to `main'
collect2.exe: error: ld returned 1 exit status
for the following code. Ideally, most of this code would be broken into .h and .cpp library files, but for the sake of the linker error, I've included them in the main.ino file. No effect, but might as well include everything, right?
[quote]
[color=# 7E7E7E]//# include linker broken for Arduino for Intel Galileo IDE[/color]
[color=# 7E7E7E]//from [/color]
using namespace std;
[color=# 7E7E7E]//define operating parameters[/color]
# define S0_PIN 12
# define S1_PIN 10
# define MUXE_PIN 8
# define MUX2_1 A0
# define MUX2_2 A2
# define MUX1_1 A4
# define MUX1_2 A5
# define BAUD_RATE 9600
# define NGYROS 2
# define NACCELS 2
typedef [color=# CC6600]unsigned[/color] [color=# CC6600]char[/color] uchar;
[color=# CC6600]class[/color] sensor{
[color=# CC6600]private[/color][color=# 7E7E7E][b]:[/b][/color]
bool s0, s1;
uchar pinx, piny;
friend [color=# CC6600]class[/color] gyro;
friend [color=# CC6600]class[/color] accel;
[color=# CC6600]unsigned[/color] pollField(uchar pin); [color=# 7E7E7E]//Mux Enable pin set low from controller constructor. Never needs to go high.[/color]
struct accelData{
[color=# CC6600]unsigned[/color] x, y, z;
struct gyroData{
[color=# CC6600]unsigned[/color] x, y;
[color=# CC6600]class[/color] accel: [color=# CC6600]private[/color] sensor{
uchar pinz;
[color=# CC6600]public[/color][color=# 7E7E7E][b]:[/b][/color]
accel(){};
accel(uchar sel, uchar px, uchar py, uchar pz);
[color=# CC6600]void[/color] accelinit(uchar sel, uchar px, uchar py, uchar pz);
[color=# CC6600]void[/color] poll(accelData* res);
[color=# CC6600]class[/color] gyro: [color=# CC6600]private[/color] sensor{
gyro(){};
gyro(uchar sel, uchar px, uchar py);
[color=# CC6600]void[/color] gyroinit(uchar sel0, uchar px, uchar py);
[color=# CC6600]void[/color] poll(gyroData* res);
[color=# CC6600]class[/color] controller{
accel accels[NACCELS];
gyro gyros[NGYROS];
accelData ad[NACCELS];
gyroData gd[NGYROS];
controller();
[color=# CC6600]void[/color] fetchData();
[color=# 7E7E7E]//filter(); filtering not used at this time. Low pass filter implemented in future?[/color]
[color=# CC6600]void[/color] sendData();
[color=# 7E7E7E]//using namespace std;[/color]
[color=# 7E7E7E]//arduino uses an initialization Setup() function and a main loop() function[/color]
[color=# 7E7E7E]//Because of the multiple function compilation, controller object must be accessible globally.[/color]
[color=# 7E7E7E]//hence:[/color]
controller* control;
[color=# CC6600]void[/color] [color=# CC6600][b]setup[/b][/color](){
control = [color=# CC6600]new[/color] controller();
[color=# CC6600]void[/color] [color=# CC6600][b]loop[/b][/color](){
control->fetchData();
control->sendData();
[color=# 7E7E7E]//from kneeSensor.cpp[/color]
[color=# 7E7E7E][b]gyro:[/b][/color]:gyro(uchar sel, uchar px, uchar py){
s0 = (sel & 1) ? [color=# CC6600]true[/color] : [color=# CC6600]false[/color]; [color=# 7E7E7E]//if sel1 & 1 is true, s0 is true otherwise false;[/color]
s1 = (sel & 2) ? [color=# CC6600]true[/color] : [color=# CC6600]false[/color];[color=# 7E7E7E]//etc.[/color]
pinx = px;
piny = py;
[color=# CC6600]void[/color] gyro::gyroinit(uchar sel, uchar px, uchar py){
pinx = px;
piny = py;
[color=# 7E7E7E][b]accel:[/b][/color]:accel(uchar sel, uchar px, uchar py, uchar pz){
pinx = px;
piny = py;
pinz = pz;
[color=# CC6600]void[/color] accel::accelinit(uchar sel, uchar px, uchar py, uchar pz){
s0 = (sel & 1) ? [color=#...
Tags (1)
Highlighted
Re: Galileo Arduino compiler/linker error: Undefined Reference to Main
That code formatting didn't work. Try this.
//from
# define S0_PIN 12
# define S1_PIN 10
# define MUXE_PIN 8
# define MUX2_1 A0
# define MUX2_2 A2
# define MUX1_1 A4
# define MUX1_2 A5
# define NGYROS 2
# define NACCELS 2
typedef unsigned char uchar;
class sensor{
private:
bool s0, s1;
uchar pinx, piny;
friend class gyro;
friend class accel;
unsigned pollField(uchar pin); //Mux Enable pin set low from controller constructor. Never needs to go high.
struct accelData{
unsigned x, y, z;
struct gyroData{
unsigned x, y;
class accel: private sensor{
private:
uchar pinz;
public:
accel(){};
void accelinit(uchar sel, uchar px, uchar py, uchar pz);
void poll(accelData* res);
class gyro: private sensor{
public:
gyro(){};
void gyroinit(uchar sel0, uchar px, uchar py);
void poll(gyroData* res);
class controller{
private:
gyro gyros[NGYROS];
public:
controller();
void fetchData();
void sendData();
//hence:
void setup(){
control = new controller();
void loop(){
gyro::gyro(uchar sel, uchar px, uchar py){
s0 = (sel & 1) ? true : false; //if sel1 & 1 is true, s0 is true otherwise false;
s1 = (sel & 2) ? true : false;//etc.
pinx = px;
piny = py;
void gyro::gyroinit(uchar sel, uchar px, uchar py){
pinx = px;
piny = py;
accel::accel(uchar sel, uchar px, uchar py, uchar pz){
pinx = px;
piny = py;
pinz = pz;
void accel::accelinit(uchar sel, uchar px, uchar py, uchar pz){
pinx = px;
piny = py;
pinz = pz;
void accel::poll(accelData* res){
digitalWrite(S0_PIN, s0);
digitalWrite(S1_PIN, s1);
res->x = pollField(pinx);
res->y = pollField(piny);
res->z = pollField(pinz);
unsigned sensor::pollField(uchar pin){
return analogRead(pin);
void gyro::poll(gyroData* res){
controller::controller(){
//set mux controls as output
pinMode(S0_PIN, OUTPUT);
pinMode(S1_PIN, OUTPUT);
//enable muxes
pinMode(MUXE_PIN, OUTPUT);
digitalWrite(MUXE_PIN, LOW);
//initialize virtual interface for sensors
accels[0].accelinit(0, MUX1_1, MUX1_2, MUX2_1);
accels[1].accelinit(1, MUX1_1, MUX1_2, MUX2_2);
gyros[0].gyroinit(3, MUX1_1, MUX1_2);
gyros[1].gyroinit(3, MUX2_1, MUX2_2);
//intialize USB CDC serial connection
Serial.begin(BAUD_RATE);
void controller::fetchData(){
for(unsigned i = 0; i < NACCELS; i++){
accels[i].poll(&ad[i]);
for(unsigned i = 0; i < NGYROS; i++){
gyros[i].poll(&gd[i]);
void controller::sendData(){
Serial.print(ad[i].x);
Serial.print(",");
Serial.print(ad[i].y);
Serial.print(",");
Serial.print(ad[i].z);
Serial.print(",");
Serial.print(gd[i].x);
Serial.print(",");
Serial.print(gd[i].y);
Serial.print(",");
Highlighted
Hmm.. That same sketch compiles fine in my (Galileo) Arduino IDE. I assume you're compiling it in the IDE, right? If so, you might enable verbose compilation errors (File/Preferences).
Highlighted
Valued Contributor I
Just to add a second data point - it compiles clean within the IDE for me too.
Highlighted
rmm200-- If that's your "second data point", I have to infer that you initially tried to compile the program for the Galileo outside the IDE--something you didn't mention. In that case I understand the problem.
A normal C/C++ program has a main() entry point that the programmer is expected to provide. In Arduino-land it's a little different. Here we write setup() and loop() routines which are called by a hidden main() program that the development environment provides behind the scenes. Something like:
void main()
setup();
while (true)
loop();
Since you are compiling in an environment that expects a main() you might add that one.
Mikal
Highlighted
Don't reply to me - I was just seconding that it compiles clean within the IDE. I tried nothing else.
Highlighted
Ah, whoops! I'm a little confused, apparently. I see that you are NOT the OP. Sorry!
Nevertheless, my guess is that either Levller is trying to compile an Arduino sketch outside the Arduino IDE, or else his IDE is damaged somehow.
