Community
cancel
Showing results for
Search instead for
Did you mean:
CTazi
Galileo Board not completing the blink example
Hi Guys ,
I have been trying to run the blink example on the board and it kept getting stuck during upload for a while so i end up removing the board from the power supply . After following some solutions in the other threads which had a similar problem i did the following :
  1. Updated the firmware of the board to 1.0.4
  2. used the Arduino 1.6.0 IDE
After trying to upload the blink example again I got the same problem. In both versions of Arduino IDE it gets stuck at this part :
Sketch uses 57,967 bytes (0%) of program storage space. Maximum is 10,000,000 bytes.
# !/bin/sh
starting download script
# clupload script to invoke lsz
Args to shell: C:\arduino-1.6.0+Intel\hardware\tools\x86\bin C:\Users\CHIDO~1\AppData\Local\Temp\build1975236674310170855.tmp/Blink.cpp.elf COM3
# Copyright (C) 2014 Intel Corporation
COM PORT
Converted COM Port to tty port /dev/ttyS-1
# This library is free software; you can redistribute it and/or
Sending Command String to move to download if not already in download mode
# modify it under the terms of the GNU Lesser General Public
# License as published by the Free Software Foundation; either
# version 2.1 of the License, or (at your option) any later version.
# This library is distributed in the hope that it will be useful,
# but WITHOUT ANY WARRANTY; without even the implied warranty of
# MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the GNU
# Lesser General Public License for more details.
# You should have received a copy of the GNU Lesser General Public
# License along with this library; if not, write to the Free Software
# Foundation, Inc., 51 Franklin Street, Fifth Floor, Boston, MA 02110-1301 USA
echo "starting download script"
echo "Args to shell:" $*
Deleting existing sketch on target
# ARG 1: Path to lsz executable.
# ARG 2: Elf File to download
# ARG 3: COM port to use.
# path contains \ need to change all to /
path_to_exe=$1
fixed_path=${path_to_exe//\\/\/}
# COM ports are not always setup to be addressed via COM for redirect.
# /dev/ttySx are present. Howwever, COMy -> /dev/ttySx where x = y - 1
com_port_arg=$3
com_port_id=${com_port_arg/COM/}
echo "COM PORT" $com_port_id
tty_port_id=/dev/ttyS$((com_port_id-1))
echo "Converted COM Port" $com_port_arg "to tty port" $tty_port_id
echo "Sending Command String to move to download if not already in download mode"
echo "~sketch downloadGalileo" > $tty_port_id
C:\arduino-1.6.0+Intel/hardware/intel/i586-uclibc/tools/izmir/clupload_win.sh: line 42: /dev/ttyS-1: Read-only file system
# Move the existing sketch on target.
echo "Deleting existing sketch on target"
"$fixed_path/lsz.exe" --escape -c "mv -f /sketch/sketch.elf /sketch/sketch.elf.old" <> $tty_port_id 1>&0
C:\arduino-1.6.0+Intel/hardware/intel/i586-uclibc/tools/izmir/clupload_win.sh: line 46: /dev/ttyS-1: Read-only file system
# Execute the target download command
# Download the file.
host_file_name=$2
"$fixed_path/lsz.exe" --escape --binary --overwrite $host_file_name <> $tty_port_id 1>&0
C:\arduino-1.6.0+Intel/hardware/intel/i586-uclibc/tools/izmir/clupload_win.sh: line 51: /dev/ttyS-1: Read-only file system
# mv the downloaded file to /sketch/sketch.elf
Moving downloaded file to /sketch/sketch.elf on target
target_download_name="${host_file_name# */}"
echo "Moving downloaded file to /sketch/sketch.elf on target"
"$fixed_path/lsz.exe" --escape -c "mv $target_download_name /sketch/sketch.elf; chmod +x /sketch/sketch.elf" <> $tty_port_id 1>&0
C:\arduino-1.6.0+Intel/hardware/intel/i586-uclibc/tools/izmir/clupload_win.sh: line 56: /dev/ttyS-1: Read-only file system
So how do i rectify this ? or is the board damaged ?
thank you
Tags (1)
AOliv17
Several people have this problem (including me), then after suffering much decided to study a way to save the sketch directly in the directory without uploading the IDE.
I will open a discussion with the procedures performed to succeed in doing this.
Att,
CTazi
Thank you ,hoping it gets solved soon
AOliv17
I believe that many have tried different ways to solve the problem by switching between USB ports on the Windows device manager, rebooting Galileo, restarting the PC ...
More is not always work and eventually becomes very annoying sometimes ..
So I started to copy the compiled file which is generated in W7 C: \ Users \ Antonio \ AppData \ Local \ Temp \ build8648427474810676811.tmp / "programa.cpp.elf"
and I am saving to a USB drive and downloading it in the sketch directory Galileo.
The details already posted in a new discussion.
Any questions or suggestions just say so!
CTazi
Ok thanks , ill try it and get back to you .
