Intel® Makers
9880 Discussions
Galileo Gen 2 Arduino Ethernet problem
JJord1
I am trying to run the basic Web client example in the Arduino IDE but I am having some problems. I have adapted it to claim a fixed IP as I don't have a DHCP server on the network.
# include
# include
byte mac[] = { 0xDE, 0xAD, 0xBE, 0xEF, 0xFE, 0xED };
IPAddress server(192, 168, 15, 64);
IPAddress ip(192, 168, 15, 177);
IPAddress dnServer(8, 8, 8, 8);
IPAddress gateway(192, 168, 15, 1);
IPAddress subnet(255, 255, 255, 0);
EthernetClient client;
void setup() {
Serial.begin(9600);
Serial.print("ip - ");
Serial.println(ip);
Ethernet.begin(mac, ip, dnServer, gateway, subnet);
delay(1000);
Serial.println(Ethernet.localIP());
Serial.println("connecting...");
if (client.connect("www.google.com", 80)) {
Serial.println("connected");
client.println("GET /search?q=arduino HTTP/1.1");
client.println("Host: www.google.com");
client.println("Connection: close");
client.println();
else {
// if you didn't get a connection to the server:
Serial.println("connection failed");
// the loop function runs over and over again forever
void loop() {
if (client.available()) {
char c = client.read();
Serial.print(c);
if (!client.connected()) {
Serial.println();
Serial.println("disconnecting.");
client.stop();
for(;;)
This is what I see as a result:
ip - 192.168. 15.177
255.255.255.255
connecting...
connection failed
disconnecting.
I have tried some workarounds found in forums (interface up, disable de SD card) but nothing worked.
What I am doing wrong?
FTinetti
Honored Contributor I
Hi Blasi,
Take a look to comments and exaamples at
HTH,
Fernando.
FTinetti
Hi Blasi,
HTH,
Fernando.
JJord1
The solution was to change Interface name. The actual commands to be run are these ones:
system("ifconfig enp0s20f6 down ");
system("ip link set enp0s20f6 name eth0");
system("ifconfig eth0 up");
