Intel® Makers
9881 Discussions
Galileo Gen 2 - Use the LAN connection direct to your PC via SSH
TPham16
Hi everyone,
I can connect to Galileo Gen 2 by wifi via SSH, but when i try to do it with LAN Wire, it not work :
First i config ip : ifconfig enp0s20f6 192.168.11.37 netmask 255.255.255.0
And I have :
enp0s20f6 Link encap:Ethernet HWaddr 98:4F:EE:05:8C:B3
inet addr:192.168.11.37 Bcast:192.168.11.255 Mask:255.255.255.0
UP BROADCAST MULTICAST MTU:1500 Metric:1
RX packets:66 errors:0 dropped:0 overruns:0 frame:0
TX packets:298 errors:0 dropped:0 overruns:0 carrier:0
collisions:0 txqueuelen:1000
RX bytes:22572 (22.0 KiB) TX bytes:107848 (105.3 KiB)
Interrupt:51 Base address:0x8000
I also connect ethernet by connmanctl :
connmanctl> services
*AO Buffalo-G-8768 wifi_e09d31862360_42756666616c6f2d472d38373638_managed_psk
*A Wired ethernet_984fee058cb3_cable
connmanctl> connect ethernet_984fee058cb3_cable
Connected ethernet_984fee058cb3_cable
connmanctl> technologies
/net/connman/technology/ethernet
Name = Wired
Type = ethernet
Powered = True
Connected = True
Tethering = False
But when i ping to 192.168.11.37 or ssh root@192.168.11.37 22, it not work,
Please help me,
Thank you,
TPham16
Thank you,
I try on other laptop, I don't set IP static on this laptop, but it's work,
1. Fisrt, I connect to galileo via UART Connector,
2. I set IP static on galileo : ifconfig enp0s20f6 192.168.11.40 netmask 255.255.255.0
3. In connmanctl , check services
4. connect ethernet_984fee058cb3_cable
5. Now, i can ping or ssh to 192.168.11.40
Maybe it have problem in old laptop's network.
But i have a question, how can i set static IP on galileo auto whenever it restart?
Thank you for help,
Have a nice day,
Thai,
FTinetti
Honored Contributor I
Hi caothai,
caothai wrote:
Hi everyone,
And I have :
Name = Wired
Type = ethernet
Powered = True
Connected = True
Tethering = False
Please help me,
Thank you,
I'm not sure I understand your post...
Your Intel Galileo does not have any wifi running with your current ifconfig output, i.e. enp0s20f6 is the Ethernet interface card of your Intel Galileo, not the wifi card. Thus, when you state:
"I can connect to Galileo Gen 2 by wifi via SSH,"
do you mean you are using the wifi of your pc/laptop, right? because the Intel Galileo wifi is not working... or I lose something...
Maybe you can send a picture with your working environment showing:
Intel Galileo Ethernet wiring to pc/laptop/router
pc/laptop wiring to router/Intel Galileo
so that I'd figure out what the problems would be.
Fernando.
TPham16
Hi FGT,
Sorry, I don't show ifconfig output wifi, ifconfig - it's really like this :
Ah, i config Ethernet IP by command : ifconfig enp0s20f6 192.168.11.37 netmask 255.255.255.0
inet6 addr: fe80::9a4f:eeff:fe05:8cb3/64 Scope:Link
RX packets:0 errors:0 dropped:0 overruns:0 frame:0
TX packets:4 errors:0 dropped:0 overruns:0 carrier:0
RX bytes:0 (0.0 B) TX bytes:300 (300.0 B)
Interrupt:49
lo Link encap:Local Loopback
inet addr:127.0.0.1 Mask:255.0.0.0
inet6 addr: ::1/128 Scope:Host
UP LOOPBACK RUNNING MTU:65536 Metric:1
RX packets:164 errors:0 dropped:0 overruns:0 frame:0
TX packets:164 errors:0 dropped:0 overruns:0 carrier:0
collisions:0 txqueuelen:0
RX bytes:15124 (14.7 KiB) TX bytes:15124 (14.7 KiB)
wlp1s0 Link encap:Ethernet HWaddr E0:9D:31:86:23:60
inet addr:192.168.11.50 Bcast:192.168.11.255 Mask:255.255.255.0
inet6 addr: fe80::e29d:31ff:fe86:2360/64 Scope:Link
UP BROADCAST RUNNING MULTICAST MTU:1500 Metric:1
RX packets:2131 errors:0 dropped:666 overruns:0 frame:0
TX packets:378 errors:0 dropped:0 overruns:0 carrier:0
RX bytes:283298 (276.6 KiB) TX bytes:58544 (57.1 KiB)
I'm using wifi to connect to galileo gen 2 board via SSH : ssh root@192.168.11.50
When I check "services" in "connmanctl", i see :
So I think, I can connect ethernet like wifi, I use command :
But it's not work, i can't connect to galileo gen 2 by LAN WIRE via SSH :
/net/connman/technology/p2p
Name = P2P
Type = p2p
Powered = True
Connected = False
Tethering = False
Name = Wired
Type = ethernet
Powered = True
Connected = False
Tethering = False
/net/connman/technology/wifi
Name = WiFi
Type = wifi
Powered = True
Connected = True
Tethering = False
Thai,
FTinetti
Hi Thai,
With your current configuration, i.e. when you have
caothai wrote:
Hi FGT,
Interrupt:49
(you should not need conman/connmanctl neither any other netowrk manager/configurations, because both interfaces are "up&running")
You should have ssh access in both interfaces, i.e. from the same computer (other than the Intel Galileo itself) you should be able to login with
from a terminal and
from another terminal
(both terminals in the same computer or different computers, other than the Intel Galileo)
Or maybe I'm losing something...
Just in case:
a) do not use connman for the Ethernet interface if you are using the ifconfig command to set the static IP.
b) did you check there is no other interface with the IP you assigned to the Intel Galileo Ethernet interface?
Please let me know.
Fernando.
TPham16
Hi FGT,
Maybe it's not static IP on my laptop, so when i ping to galileo on laptop, it go but don't receive data back.
I try set Static IP on my laptop by add new ethernet connection (I use Ubuntu 14.04 LTS) with ip 192.168.11.38 , but now my laptop can't connect to internet or galileo too.
----> But when i disconnect this connection, i can connect to galileo by LAN WIRE and WIFI too.
I really don't understand what's happen, but it's really work.
1. Why when i set static IP on my laptop, i can't connect to internet or galileo too?
2. Why after i disconnect ethernet connection, Ethernet IP of my computer follow DHCP but it can connect to galileo by LAN WIRE?
I'm newbie of galileo and network too,
Thank for your help,
Thai,
FTinetti
Hi Thai,
If there is some configuration/scenario in which
then use that, I'll try to explain some possibilities for errors, but I'm far from being sure about what happens.
This seems to be a problem in your laptops's network configuration, the Intel Galileo network is unrelated to this error. I've had many problems adding new network ethernet connections in Ubuntu. I guess it's because I don't know how to configure it, and in most cases my computer is left with no internet connection. Actually, if your laptop interfaces are working, do not change them/create any new interfaces. Actually, this may answer your question:
i.e. your new setting is not fine and generates that your interfaces do not work properly so your laptop becomes disconnected.
About
I do not fully understand the sequence, but anyhow
a) Those are laptop's network configuration problems, not Intel Galileo ones.
b) If there is a scenario in which you are able to connect to your Intel Galileo, do not change it.
HTH,
Fernando.
TPham16
Thank you,
Thank you for help,
Have a nice day,
Thai,
FTinetti
caothai wrote:
Thank you,
Thank you for help,
Have a nice day,
Thai,
I think you can follow the steps described at so that your Intel Galileo sets the static IP each time it starts running.
HTH,
Fernando.
