Community
cancel
Showing results for
Search instead for
Did you mean:
rthat
Galileo Gen 2 not detected when SD card insert
After I have completed the required procedure I have plugged microUSB to Galileo and connect to PC. this time file explorer opens directly and shows files on SD card . Galileo Gen 2 not detected on arduino IDE,. For checking , I pulled microSD card and then Galileo connect to PC this time Galileo Gen 2 detected on arduino IDE
FTinetti
Honored Contributor I
Hi Rashid_Thattayil,
This happened once to me, and it was because I inserted the SD card after the Galileo started (i.e. booted without the SD card). Insert the SD card before Galileo power up.
Just in case: please detail what is "the required procedure" you completed.
Fernando.
Sergio_A_Intel
Yes, follow FGT's suggestions and make sure to supply the Galileo with enough power. You can use a 7-15VDC power supply for the Gen 2.
Sergio
Carlos_M_Intel
Hi Rashid,
Do you have updates on this?
Could you post a screenshot of what you get on the Device Manager and the files on the SD card?
Charlie
rthat
hi
this problem due to ,my CDC serial driver is not update .problem solved when it update
