Intel® Makers
9880 Discussions
Galileo board - Using two serial i/o interconnections - Arduino Serial2 through 3.5mm jack
MMich28
I'm using the Galileo board with the Arduino-IDE. I'm using the board on 3.3V by setting IOREF.
I need to have 2 serial ports available to connect to two devices working on 3.3V.
I'm currently using:
-Serial: USB communication to PC
-Serial1: pin 0-1 connection to one device
I need another serial port for the other device but:
-Serial2 seems connected to the 3.5mm jack
-Software serial Arduino library is not supported
Following the first possibility, I connected a jack, opened the cable and connected the internal TX-RX wires to my second device, but it doesn't work.
I checked the interconnections with a multimiter and they are ok, so the problem isn't in faulty cables.
Still the jack works on 5V, so I put a voltage regulator on the interconnection to translate the 5V into 3.3V.
I checked the serial communication with a logic analyzer (before and after the voltage regulator) and nothing is sent through the RX-TX lines of the jack.
My program is simply something like:
void setup() {
Serial.begin(9600); //USB communication
Serial1.begin(19200); //first device pin 0-1
Serial2.begin(19200); //second device jack
void loop() {
//take string str from USB Serial
//send it to the 2 devices
Serial1.print(str);
Serial2.print(str);  //if the string is received, the devices send and ACK acknowlegde on the serial line and I print it on the PC screen.
It compiles without any problem Serial1 works perfectly, but Serial2, which is the jack, remains silent.
How can I solve the problem?
FTinetti
Honored Contributor I
Maybe you can use pins 2 & 3 as suggested at https://forums.intel.com/s/question/0D50P0000490LfhSAE/myserial-library-for-gen2 ?
HTH,
Fernando.
FTinetti
