The Intel have provide stmmac Ethernet driver for UEFI(X86) on Galileo Gen2??
Hello TrusrtEC,
If you use the command lsmod it'll display all kernel modules and, as you can see, stmmac is included in the Galileo image. Also, if you need more information about the module you can use the command modinfo stmmac.
The module is located in the following directory: /lib/modules/3.8.7-yocto-standard/kernel/drivers/net/ethernet/stmicro/stmmac
Diego.
Hello TrusrtEC,
Let me check about this. I'll post the information I find about it as soon as possible.
Diego.
Hello TrusrtEC,
Diego.
