Intel® Makers
9868 Discussions
Galileo gen1 arduino ide problem
aisar
Firstly I want to say that I worked in the past with the arduino ide on some arduino uno projects, so i am not a complete newbie when it comes to arduino ide.
I just got an intel galileo gen1 board from my university and I wanted to test the blink project. I installed the board using this guide https://software.intel.com/en-us/articles/intel-galileo-board-assembly IoT - Intel® Galileo Board Assembly using Arduino* | Intel® Developer Zone after i opened the ide, I checked the tools->board/port to be the right ones. I uploaded the program but it fails, i get this error:
Arduino: 1.6.4 (Windows 8.1), Board: "Intel® Galileo"
i586-poky-linux-uclibc-g++: error: C:\Users\isara\AppData\Local\Temp\build5158321505411607872.tmp/core.a: No such file or directory
Error compiling.
This report would have more information with
"Show verbose output during compilation"
enabled in File > Preferences.
My os is win10 x64.
Diego_V_Intel
Hi kiradead,
I noticed that the log shows "Windows 8.1", but you confirmed you are using Windows 10. That might be the reason of this issue. Anyhow, I recommend you to download the Arduino IDE 1.6.0 and check if you get the same error: http://downloadmirror.intel.com/24783/eng/IntelArduino-1.6.0-Windows.7z http://downloadmirror.intel.com/24783/eng/IntelArduino-1.6.0-Windows.7z
Additionally, post a screenshot of the Device Manager while the board is powered with the DC power supply and the USB client is connected to the PC. I'd like to check the COM port status.
Diego
Diego_V_Intel
Hi kiradead,
Diego
FTinetti
Honored Contributor I
I've seen this error reported previously: , did you already upgrade the Galileo firmware?
Fernando.
Diego_V_Intel
Hi kiradead,
I'd like to know if you still need help with your board, or if you were able to fix the issue.
Diego
aisar
Sorry for not replying early, the ide you recommended works. I do have another question, is normal for the compilation,linking etc and uploading to take almost 1min?
Diego_V_Intel
Hi kiradead,
Yes, that's normal. The process of uploading a sketch takes around 1 minute.
Diego
