Community
cancel
Showing results for
Search instead for
Did you mean:
PPraj1
Galileo support in windows 8?
what are the problem when working on windows 8 with Galileo board?
Community Manager
Hi Techieguy,
Thanks for your interest in the Intel Galileo Platform.
I'm sorry to hear that you are having problems with your Galileo. Could you be so kind to explain us what sort of issue you are experiencing when you used the Galileo on Windows 8.
I will be waiting for your reply, have a nice day!
-Jose P.
FTinetti
Honored Contributor I
Hi Techieguy,
I don't know if I understand the question... I've used the Arduino IDE for Intel Galileo (small) projects. I've have some problems, but they have been dependent on too many specific details, most of them related to the specific (small) projects on which I've worked.
I suggest that if you have some specific problem then open a thread and report, ask, etc. about your specific problem, just as Jose P. suggested.
HTH,
Fernando.
PPraj1
Arduino: 1.8.1 (Windows 8.1), Board: "Intel® Galileo Gen2"
Sketch uses 90024 bytes (0%) of program storage space. Maximum is 10000000 bytes.
# !/bin/sh
starting download script
Args to shell: C:\Users\plavin10\AppData\Local\Arduino15\packages\Intel\tools\sketchUploader\1.6.2+1.0/x86/bin C:\Users\plavin10\AppData\Local\Temp\arduino_build_864135/KeyboardController.ino.elf COM18
# clupload script to invoke lsz
COM PORT 18
# Copyright (C) 2014 Intel Corporation
Converted COM Port COM18 to tty port /dev/ttyS17
Sending Command String to move to download if not already in download mode
# This library is free software; you can redistribute it and/or
# modify it under the terms of the GNU Lesser General Public
# License as published by the Free Software Foundation; either
# version 2.1 of the License, or (at your option) any later version.
# This library is distributed in the hope that it will be useful,
# but WITHOUT ANY WARRANTY; without even the implied warranty of
# MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the GNU
# Lesser General Public License for more details.
# You should have received a copy of the GNU Lesser General Public
# License along with this library; if not, write to the Free Software
# Foundation, Inc., 51 Franklin Street, Fifth Floor, Boston, MA 02110-1301 USA
echo "starting download script"
echo "Args to shell:" $*
# ARG 1: Path to lsz executable.
# ARG 2: Elf File to download
# ARG 3: COM port to use.
# path contains \ need to change all to /
path_to_exe=$1
fixed_path=${path_to_exe//\\/\/}
# COM ports are not always setup to be addressed via COM for redirect.
# /dev/ttySx are present. Howwever, COMy -> /dev/ttySx where x = y - 1
com_port_arg=$3
com_port_id=${com_port_arg/COM/}
echo "COM PORT" $com_port_id
tty_port_id=/dev/ttyS$((com_port_id-1))
echo "Converted COM Port" $com_port_arg "to tty port" $tty_port_id
echo "Sending Command String to move to download if not already in download mode"
echo "~sketch downloadGalileo" > $tty_port_id
Deleting existing sketch on target
# Move the existing sketch on target.
echo "Deleting existing sketch on target"
"$fixed_path/lsz.exe" --escape -c "mv -f /sketch/sketch.elf /sketch/sketch.elf.old" <> $tty_port_id 1>&0
-su: rz: command not foundroot@galileo:~# 00000000123273-su: 00000000123273: command not foundroot@galileo:~# An error occurred while uploading the sketch
Invalid library found in C:\Program Files (x86)\Arduino\libraries\Sketchbook_Starter_Kit_V2.0: C:\Program Files (x86)\Arduino\libraries\Sketchbook_Starter_Kit_V2.0
This report would have more information with
"Show verbose output during compilation"
option enabled in File -> Preferences.
FTinetti
Hi Techieguy,
Plase show:
a) The Device Manager window before and after you plug in your Intel Galileo (which should be already turned on)
b) Set the proper Intel Galileo card in the Arduino IDE "Tools" options
c) The IDE compile/verify output
What is the IDE version you are using?
Fernando.
PPraj1
many time i am trying to update CDC serial driver but it not updated
FTinetti
I see, your Intel Galileo USB connection to the PC is not recognized. Follow the instructions at
https://software.intel.com/en-us/installing-drivers-and-updating-firmware-for-arduino-windows IoT - Installing drivers and updating firmware for Arduino on a system with Windows* | Intel® Software
and take into account that "Gadget Serial V2.4 or Galileo port" in your case is "CDC serial".
If you have trouble please take a look at and/or let us know.
HTH,
Fernando.
Community Manager
Hi Techieguy,
Were you able to solve your issue with the CDC serial? Please let me know in order to assist you.
We will be waiting for your results, have a nice day!
-Jose P.
PPraj1
Hi Jose,
i have windows 8.1 and i tried all the possible ways but still driver not updated..i see news on windows that it pulls support for Galileo
gen 2 as not hardware compatibility with win 8.1 .. so is right??
this screen appear while i follow your instruction
PPraj1
Hi Jose P.
Jose P thanks for support to solve issue..
finally come to conclusion of this issue ..actually problem in Galileo board, may be some hardware issue. i just change board got another same Galileo board and in device manager it will show Gadget serial V2.4 and update it . now working fine after update driver show Galileo COM port and after start communicating with hardware.
PravinKumar
Consultant :intelligent system
FTinetti
Techieguy wrote:
Hi Jose P.
PravinKumar
Good to know. Sometimes, faulty cables make trouble too.
BR,
Fernando.
Community Manager
Hi Techieguy,
We are here to help! Please don't hesitate to contact us back if any question comes up.
Have a great day!
-Jose P.
