Intel® Makers
9872 Discussions
Generating Audio PWM on Curie / Arduino 101?
RRobe12
Has anyone implemented basic PWM for audio on the Arduino 101 / Curie? It could be as simple as:
http://playground.arduino.cc/Code/PCMAudio Arduino Playground - PCMAudio
or as comprehensive as:
https://github.com/TMRh20/TMRpcm GitHub - TMRh20/TMRpcm: Arduino library for asynchronous playback of PCM/WAV files direct from SD card. Arduino Uno,Nano…
... but naturally adapted to the Intel / Quark registers.
Failing that, can anyone offer guidance on taking over a pair of timers on the Arduino 101 and configuring them directly from an Arduino sketch? In particular, are the register definitions available to sketches? Or do I have to drop down into C++?
Thanks in advance,
- rdp
Community Manager
Hi rdp,
Thank you for contacting us. You'll find a more detailed response to your Arduino 101 question in https://www.arduino.cc/en/Main/ArduinoBoard101 https://www.arduino.cc/en/Main/ArduinoBoard101 . Arduino 101 is directly supported by Arduino.cc.
You can find their forum here http://forum.arduino.cc/index.php?board=103.0 http://forum.arduino.cc/index.php?board=103.0 .
-Sergio
